How ironic...HATCH STUCK OPEN!
Old Nov 2, 2006 | 09:02 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
I popped the hatch so I could place some things in the back, completely forgetting the car doesnt have any wiring done yet. So basically my hatch motor is stucked in the "engaged" mode, meaning the motor is pulled down and I can't close the hatch because it still believes it is closed. How do I get this motor to...I dont know whats the word I'm looking for...move up? lol. Help appreciated! It's starting to rain!
Old Nov 3, 2006 | 07:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
remove the plastic panel covering the motor and you should be able to see the pull down motor, if you get a screwdriver and stick it into the latch where the hatch catch should be and press down on the mechanism and turn the harch key, you can get the hatch motor to open back up (only if the hatch motor has power if not i have no idea). ive had this happen to me before and it was nerveracking the first time because i had no clue how these things worked and thought i f-ed up my car
Old Nov 3, 2006 | 10:28 PM
Morder.'s Avatar
Engine: LB9 305 TPI
I don't have power though
Old Nov 3, 2006 | 10:34 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
find the wires going to the motor and jump 12V and groung to them from a car battery, I think that should work.
Old Nov 4, 2006 | 12:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need it to move up, just open a door to relieve the air pressure inside the car and slam the hatch.
Old Nov 5, 2006 | 05:01 AM
Morder.'s Avatar
Engine: LB9 305 TPI
Doesnt work. The part where the hatch latches shut is sucked down, as if it still believes it is closed.
Old Nov 5, 2006 | 06:31 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
yes, the same position it was in when you decided to open it from the closed position.. it can again reach the latch ;0
Old Nov 5, 2006 | 09:04 AM
Stevo's Avatar
Car: Pair of 92 Z28s
I know what your talking about...if you press it close it just bounces on the bottom latch...right? When mine craped out and screwing around with it it was in the same position that it would not let you close i finally messed with it and it opened again..You will have to get power to it somehow just to get it to unrelease...THEN you can slam it close and manually unlock it with the key to slam it closed again and so on.
Try with a flathead...you maybe able to unlatch it
Old Nov 5, 2006 | 11:26 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're not slamming it hard enough. In the down position with no power, the hatch works exactly like it did on the earlier cars before that ridiculously fragile hatch motor was introduced.
Old Nov 5, 2006 | 12:34 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
find the switch on the hatch lift motor... it looks like the one pictured below. FLip the switch on the switch to actuate its motion.
Attached Thumbnails How ironic...HATCH STUCK OPEN!-hatch-switch-002-2   How ironic...HATCH STUCK OPEN!-hatch-switch-003-2.jpg
Old Nov 5, 2006 | 01:15 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Why don't u just get power to it ?, I 've done it too and I could never get it to close by slamming the hatch closed. What wiring is missing?
Old Nov 5, 2006 | 01:27 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
That's happened to me before, and I just took the panel off to expose the motor, got a screwdriver in there, and slowly forced it up. Didn't take that much force, either.
Old Nov 5, 2006 | 03:31 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Un-plug the blue wire from the red/white stripe wire. Jumper +12v to that blue wire to power the hatch pull-down motor. It should raise back up.
Lon
Old Nov 6, 2006 | 01:03 AM
Morder.'s Avatar
Engine: LB9 305 TPI
Doesnt work, sorry.
Thanks everyone, I'm going to try giving it some juice tomorrow. Should I use a car battery? Smaller?
Old Nov 6, 2006 | 11:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It works on my 88. Maybe you need to eat your Wheaties.
Old Nov 6, 2006 | 11:19 AM
Morder.'s Avatar
Engine: LB9 305 TPI
Strength has nothing to do with it. I have slammed the holy hell out of this thing, it aint closing any time soon by strength alone.
Old Nov 6, 2006 | 05:37 PM
John Prychka's Avatar
Car: 1987 Z28
Transmission: auto
Axle/Gears: ?
I have a similar problem caused when closing on a cardboard box. I think the motor "stalled out". There must be a fuse somewhere... but where??
Old Nov 6, 2006 | 06:03 PM
lonsal's Avatar
John P: in your case the hatch motor needs to just be re-set. Reac inside the hole and press on the striker-sensing switch (it is a small black paddle just in front of the latch). Hold that switch down and it will power down the rest of the way. Then release the switch and the unit will cycle up and be re-set. The unit powers down ONLY while that switch is being depressed. If it turns out you have no power, the fuse on a Camaro is a 15 amp in the #3 slot (top row, third column from the left). On Firebird it is a 15 amp fuse that is attahed to the side of the fuse block.
Lon
Old Nov 7, 2006 | 12:47 PM
Abubaca's Avatar
sorry, but I didn't read every post, maybe this has been brought up.
...if the latch is closed, you can open it with a screwdriver. It'll "click" and stay open.
My motor went completely dead once. I moved the latch mechanism all the way up by hand. Then I just closed the hatch like normal, and opened it with the key like normal. Of course, it didn't pull the hatch down and seal it against the weatherstripping since the motor was dead, but it was fully locked and didn't open. I just sat a little high. It was a perfectly good temporary fix.
Old Nov 7, 2006 | 08:48 PM
Morder.'s Avatar
Engine: LB9 305 TPI
It's not closed though, its open and this car is a project so I still dont have in the ecm and engine harnesses, therefore there is no power going to the car.
Where exactly do I hook up the battery to? I saw a connector near the motor that I believe had 2 wires on it, a black and a yellow, but I believe it was a 4 prong female.
Old Nov 8, 2006 | 08:28 AM
Abubaca's Avatar
If it's open, and you can't get it to close when you shut the hatch, you have one of two problems.
---First, the actual mechanism is stuck "down". With no power you'll need to manually move it up high enough so it can grab the hook on the hatch. You don't need to hook up power, although that might work. Just get in there and move it by hand.
---Second, the latch is broken, although that doesn't seem to be the case.
Old Nov 8, 2006 | 09:03 AM
CrazyHawaiian's Avatar
Car: too many ...
This has happened to me on my 89 IROC-Z. The hatch motor had power but the motor went out while in the down position. I was still able to close the hatch by slamming it, but I didnt like the idea of slamming it all the time. This car didnt have hatch struts so it was really easy to slam it, maybe unhooking your hatch struts will make it easier? I dunno, but anyway, there are a few different versions of the hatch motor, so your experiences may be different from other people. The one I had on my IROC-Z allowed access to the plastic gear that moves the locking mechanism up and down on that rail. The gear was located under the latching mechanism by the motor itself. The gear was clear and made out of plastic. Usually the hatch motor is what turns that gear. I used a flat head screwdriver to move the gear manually and move the locking mechanism up until the hatch closed. Like someone already said, its a good temporary fix but be prepared to hear some rattles. If you really need it to close flush with a broken motor you can do it the way I've described, then when the hatch is closed get into the car and manually turn that gear again to bring it down. Kind of a tight fit when you try to do that one (I'm a big guy I almost got stuck hahaha).
Old Nov 8, 2006 | 01:54 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
just fixed my stuck open hatch as well, all it need was a slam to shut it, now everything works fine. I think the battery was dissconnected when the hatch was up.
Old Nov 8, 2006 | 04:17 PM
BlownUp Blue's Avatar
We run a garage, and that "slamming" the hatch is the best way to break the hatch motor. Don't ever slam the hatch if it doesn't close! And holy crap don't slam it if the motor's in the "down" position!
Old Nov 10, 2006 | 12:36 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
i ran into this problem the other day fixing a friends 91...
The hatch itself became so far off alignment, that the rod the hatch locks with, was way too far back and would not even hit the locking mechanism... Since we didn't have tme to remove the deck lid to realign, i simply unbolted the rod, and flipped it around to point in the opposite direction. Locked instantly...
Old Nov 11, 2006 | 03:52 AM
Morder.'s Avatar
Engine: LB9 305 TPI
Is anyone reading my initial question? Slamming it will not solve anything, where do I give this baby power? What connector am I lookin for?
Old Nov 11, 2006 | 07:25 AM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
assumeing ya have the harness with relay there but just not power run back to it yet....on my 90 there is a blu wire (batt + )and a blk wire (batt -) those are the 2 wires i used to supply power to the motor assembly.Since the hatch's hook isn't in the motor it should go to up position seeking the hatch catch.I used those 2 wires with a 18 volt cordless drill batt at the salvage yard to test the assembly b4 purchase.You might be able to use a 9 volt but kinda doubt it.As for soursein thepower just grab some old junk speaker wire and pop the hood.Tap the batt posts and try ta remember when ya get to the back the car which one is + and which is -.Or if ya have an old plug into the lighter toy use the cord just remember polarity.Hope it helps.
P.S. is ya need it i have posted pics in another thread askin a similar question just hollar if ya need them or search for it under the lists if my posts.Again hope this helps......Bill
Old Nov 13, 2006 | 11:21 AM
Bill/T/D/Y's Avatar
hey Morder??Did ya get it fixxed??
Old Nov 13, 2006 | 12:41 PM
Morder.'s Avatar
Engine: LB9 305 TPI
I havent had time to look at it until today, I shall find out!
Old Nov 13, 2006 | 01:28 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You shouldn't need power. Using a screwdriver you can open the locking mechanism up and then you will be able to close it like a regular trunk.
Old Nov 14, 2006 | 12:54 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Is this something all Camaros after a certain year have? If so I am quite sure mine is broken. :/ This pulls down on the hatch instead of having to close it manually?
Old Nov 14, 2006 | 09:47 AM
Bill/T/D/Y's Avatar
Yea it pulls the hatch the last inch or so down.Ya close till it engages and then it snuggs the hatch down tight.The mounts are different but ya can retro fit if ya wanna do the work.It wouldn't suprize me to find some model caddies have a trunk mechanism simular that could be fit into the non motorized latch hold down areas.It works real well as long as ya don slam the hatch.Which tends to tear up the assembly.
Old Nov 14, 2006 | 12:10 PM
I don't think the convertables have the pull down.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Pac J
May 17, 2020 10:44 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
steimel94
Sep 20, 2015 12:46 PM
ctoledo0834
Sep 18, 2015 04:16 PM
