sticker on bumper
Old Dec 8, 2006 | 10:46 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
sticker on bumper
wgats the cleanest and best way to remove a dealership sticker from the rear bumper??
Old Dec 8, 2006 | 10:49 PM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
they make and glue remover just for that look at walmart ore anvance auto parts or auto zone and a for a glue remover for decows
Old Dec 8, 2006 | 10:53 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
try heating it up first with a hair dryer or heat gun, theres less mess that way
Old Dec 8, 2006 | 10:57 PM
Engine: 305 tbi
but doing that u will still have glue that will not come off well and you could still pull off the pant if u just heat it up with a head gun . the best thing is glue remover if u want to save your pant.
Old Dec 8, 2006 | 11:00 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
but being a dealership sticker not a parts company or just bumper sticker the adhesive will be less agressive, go with the hair dryer first, and save some money at the same time
Old Dec 8, 2006 | 11:03 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
ok cool thanks alot guys
Old Dec 8, 2006 | 11:04 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
hey NP, good luck
Old Dec 8, 2006 | 11:07 PM
Engine: 305 tbi
those dealerships dont want those names off the cars they tends to be even stronger then the factorey ones and about saveing money it will cose alot more to get get the bumper repanted then just buy the glue remover in the first place so i would not take the chance and a facked that u can not make the pant mach if u do have to repanted because most cars that olds sarted to fade and a fade it car is so hard to mach
Old Dec 9, 2006 | 12:34 AM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
If it's factory paint, just heat it and pull it off slowly. Then use a 3M adhesive remover. Not a big deal.
Old Dec 9, 2006 | 06:29 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I used a razor blade before, and it came off easy as cake but it was like 6 yrs old, and came off almost to easy
Old Dec 9, 2006 | 06:45 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
use a heat gun and a plastic razorblade(dont use a real razor blade!!!!) then use goo-gone to remove the left over glue.
Old Dec 10, 2006 | 05:36 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What I did.
JamesC
Old Dec 10, 2006 | 10:12 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
CYARS92, gave you the right answer..............
Old Dec 10, 2006 | 01:22 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
does any of that stuff hurt your paint/clearcoat?
Old Dec 10, 2006 | 02:01 PM
Stevo's Avatar
Car: Pair of 92 Z28s
no, just make sure you get some wax over the parts you got it on after.
For me, ive always just used a heat gun and some type of decal remover and have had great success everytime.
Old Dec 10, 2006 | 02:56 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
all it is,is a white sticker and on a red car it looks tacky I dont wanna hurt the paint or clear I do have a friend that works at a big chevy dealership here I might just go see what he says or if he might be able to take it to the body shop or detail shop and get it removed...but thanks alot for all the tips I will try a couple of those first
Thirdgen89GTA
Nov 26, 2015 11:04 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
