Front Parkin lights
Old Jan 14, 2007 | 01:33 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Front Parkin lights
My Parking lights on the front of the bumper look dirty inside. How can you take these out to clean them?
Old Jan 14, 2007 | 01:34 PM
Gramps's Avatar
Car: 87 Camaro IROC
get under your car and remove them, there are 2 screws holding the bulb housing in there.
EDIT:its probably a 7mm socket that you need, and be very carefull when installing not to tighten too much or you could break the plastic.
Old Jan 14, 2007 | 09:36 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
just buy some new ones, you will be AMAZEd at how much tehy will make your car look better...
http://www.moderndaymuscle.com/exterior1?start=60
-- http://www.moderndaymuscle.com/inc/sdetail/869
Old Jan 15, 2007 | 06:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Gramps
get under your car and remove them, there are 2 screws holding the bulb housing in there. EDIT:its probably a 7mm socket that you need, and be very carefull when installing not to tighten too much or you could break the plastic.
I filled the housing with Simple Green and hot water; I let it sit for awhile, then shook the heck out of it and went through the process again several times. Also polishing the lense itself will noticeably help (you might consider a search for more info on that).
JamesC
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
