Swapping out Lexan t-tops for glass...
Old Jan 14, 2007 | 09:17 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
A fellow board member tpihearse tried to sell me some glass tops last summer, however they did not fit on the car right...near the windshield the top left a gap when it was cranked down. He gave me new t-top latch pin receivers to install, and said once I did glass tops would fit. However, he and I were both surprised they didnt fit anyway. I remember all the way back in 1990 or so, my mother's '89 RS received glass tops under warranty...the dealer swapped them off an 8k mile car on the lot because her Lexan tops were already cracking. They went right on with no modification.
So why does my '91 require new receivers, or am I missing something? By the way, tpihearse if you happen to see this I am planning to call you this week about grabbing some glass tops from you
Thanks to anyone who can help!! Hopefully there'll be no more Lexan soon!!!
Old Jan 14, 2007 | 09:49 PM
Gramps's Avatar
Car: 87 Camaro IROC
mayb your glass ones got adjusted before you got the car. or the lexan ones were modified. but if all you have to do is adjust your pin reciever pieces then thats not that bad.
Old Jan 15, 2007 | 09:23 AM
Jason E's Avatar
So I don't need to remove my original Lexan pin receivers?? I can just adjust them? How can I do that?
I swore I needed to change the pin receivers, based on other things I had seen on here...
Old Jan 15, 2007 | 04:28 PM
Pocket's Avatar
Car: 91 Trans Am
First off, whats different about the t-tops
The pin size or do they simply not ft right or latch on
GM used 2 diff pin sizes over the years, large and small
If this is your problem then just remove the cover and swap the linkage over from your old lexans
If they dont fit or latch right then you just need to adjust the recievers
Take down the little plastic trim pieces that cover where the t-top pins go in, there are 2 screws on each reciever letting you move it up down and at angles
Trial and error here
Old Jan 16, 2007 | 11:29 AM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Just to reiterate what Pocket has already said:
There is no reason why glass tops won't fit on a Lexan-top equipped car. I swapped out my squeaky Lexan tops for glass this past summer.
The only area that might be causing a problem here are the pin receivers. Earlier receivers had smaller holes, for the smaller pins on the t-tops. The last couple years of thirdgen production saw t-tops with larger pins, so the recivers had larger holes. Match your receiver to your pin size, adjust the tops properly, and you'll be fine.
Old Apr 2, 2013 | 12:44 AM
gio.cortes89's Avatar
Car: 92 firebird
Engine: v6 mpi
Re: Swapping out Lexan t-tops for glass...
where could i get receivers for a small pin? i have the lexan tops and also want to change them to glass ttops--however the weatherstripping doesnt not align right and leaves a gap on both ends so i was thinking of switching the pins and weatherstripping from the lexan to the glass
Old Apr 2, 2013 | 07:17 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
try a junkyard. i swapped mine from lexan to glass. the reciever just needs adjusting. i bought new weatherstripping for it though.
Old Apr 4, 2013 | 09:45 PM
hdavis2005's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI to 305 carb
Axle/Gears: 323
I switched from Lexan to glass with no major problem. Just had to adjust them. Had to take them off a few times that's all.
Street Lethal
Apr 30, 2019 12:14 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
aaron7
Aug 26, 2015 09:45 AM
t-top89
Exterior Parts for Sale
Aug 21, 2015 09:52 PM
