POWER WINDOWS
Old Jan 18, 2007 | 06:37 PM
RICEKLR's Avatar
POWER WINDOWS
well im trying to lose some unnecessary weight in my car and i realize that the door are really heavy. anyone out there know how hard it will be to get rid of the power window? and how much weight might i lose?
Old Jan 18, 2007 | 06:48 PM
92fbodylover's Avatar
Car: 92 rs camaro ,92 covt trans am
Engine: 305 tpi , 305 tbi
Transmission: auto
it would not be hard to swap over to manual windows , not sure how much wight you would lose cuase you would have to put in the maual hardware into the doors.
Old Jan 18, 2007 | 09:12 PM
90_T/AGTA's Avatar
Car: '90 GTA
I dont even think you would lose that much weght.
Old Jan 18, 2007 | 10:36 PM
Gramps's Avatar
Car: 87 Camaro IROC
if you wanna lose weight get a fiberglass door, but if your gonna put a lexan window in there you gotta get a track system and crank and all that bs. if you wanna really lose weight you can start by removing your hood and replacing it w/ a glass one, but if you REALLY wanna save weight at the track, strip the doors, hood fenders and ground effects. next drop out your dash and console, take off the T-Tops (if equipt) and the headliner too. then you can start by looking at the front end, replace those front tires with something light, like mayb a couple spare tires from a donor car. and since your at it, why not cut away all your trunk space and remove that heavy hatch. cut away your rear bumper and all the electronics as well. now u can go into the engine bay and start removing things like the wiper motor and assembly, all the vents and ducting, get rid of light assembly (fog lights included). strip out everything on the interior including the pass seat and carpet. and get rid of the rear security cover (thing that rolls up...i forget the technical name) and your done. <<<gauranteed better strip times>>>
or you could just get a fiberglass hood...mayb just go for the hood.
Old Jan 18, 2007 | 10:42 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
youre not going to lose any real weight, the only thing you would be eliminating are the window motors and they are by no means heavy
thats too much work for the minute weight you would lose
bad idea
ppl are such noobs sometimes and come up with some wierd ideas.
jut wanted to say that, for whatever reason i dont knwo why lol
hum
good luck
Old Jan 19, 2007 | 12:16 AM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Heh....got Air Conditioning?
Old Jan 24, 2007 | 01:58 AM
83 Crossfire TA's Avatar
Didn’t someone post a few years ago, that when all is said and done power windows end up a few oz ligher then manual on these cars?
Old Feb 3, 2007 | 03:46 AM
RICEKLR's Avatar
well...if its not going to be worth it to do all that work...
anyone know where i can get fiberglass body panels?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
