cowl 5in hood
Car: 84 Camaro
Engine: 400sb
Transmission: built 700r4
cowl 5in hood
ok i have an 84 camaro i blew the trans in, so im doing a bunch to it right now and i just installed a new intake and its a performer rpm. and its the one that is a inch taller then normal rpms. problem is my 2in cowl hood no longer fits with it when i put the carb and air filter on. does anybody have a picture of a car with a 4 or 5in cowl so i can see which i like more
Thanks, Ryan
Thanks, Ryan
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
there are tons of pics out there.. hit the search button and go find em.. always do a search and you will find what you are looking for..
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
is it the performer rpm air-gap? I dont see how that intake won't fit on a 2" cowl. Are you running a drop base air cleaner? I can fit the normal performer rpm intake, 650dp, and air cleaner under a stock hood. But my sig pic is a 4" cowl, but I have a much bigger setup than what you're talking about.
Car: 1984 Trans Am
how can your setup not be able to fit under there?? i have a vic jr. with a 1" spacer (about 5/8" taller than an airgap), a 750demon, and a 9/16th inch raised base 14"x3" extreme filter.. the wing nut for the air cleaner barely clears my scoop.. and its maybe 2.5" at that part..
Car: 84 Camaro
Engine: 400sb
idk guys i have a new performer rpm intake a holley 650 and a k&n air filter and the hood wont close and i belive its a 2in. its the third gen ram air that looks like an old mustang hood like the machs. ill take pictures when i get home its not all togather yet tho so maybe it will fit but i dont think so
Car: 84 Camaro
Engine: 400sb
https://www.cervinis.com/product.aspx?car=1&id=1126#114 the second hood on that page is the one i have. i think its a 2incher it might not be but idk.... im at my dads house right now when i go home i will look at it till then here are some pics of my car. http://s86.photobucket.com/albums/k1.../The%20Camaro/
Car: 1984 Z28
that doesn't look like a drop base air cleaner from those pics. Did you try looking to see if there's a brace under the hood that the air cleaner is hitting that needs to be cutout?
Car: 84 Camaro
Engine: 400sb
yea i didnt see anything but the way it sits the hood is just set on there so maybe when i put the hood brace or whatever its called. (lol im am drawing a effing blank here) it will lift the back enough but i dont think so we will see
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
you need a drop base air cleaner. i have a performer rpm intake and a 700 double pumper and a 14x3 DROP BASE air cleaner all under a stock hood with no problem. ill take that hood though if you wanna get rid of it
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I run a victor Jr. intake and a Holley 750 double pumper with a 14 inch drop base air cleaner under my stock hood also.
Car: 82 T/A
Engine: stock 350
Re: cowl 5in hood
I had the same problem with my 85'. i ended up cutting a hole in my stock hood, and just letting it sit like that. But with a 1inch spacer, it only sticks out maube a 1/2 inch, and i dont have a drop base.
Car: 1992 Pontiac Firebird
Engine: 3.1
Axle/Gears: 3.42 Auburn Posi
Re: cowl 5in hood
Just get a drop base cleaner and you'll be fine. That's the only "Ram Air" hood that should ever go on a Camaro, I hate seeing Pontiac hoods on a Camaro. 4-5" cowls on Camaros look too overdone and lame.
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Car: 84 Camaro
Engine: 400sb
Re: cowl 5in hood
i agree noahthepurdy the pontiac ram airs on and third gen i beilve is just ugly and yea big cowls do get sick but then again i kinda like them depends on how the car is done
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: cowl 5in hood
ive got a 4", on a bird, i can fit a drop base filter with a 3" filter under the stock hood no problem. i have my filter sitting high, because i eventually and going to seal up the bottom of the cowl from the engine bay and take advantage of some colder air.
Re: cowl 5in hood
nice TA! but please drop it, then it will be just about perfect.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
