Should I shave my gas cap?
Old Mar 20, 2007 | 01:16 AM
1986camarojoe's Avatar
Car: Z28
Engine: 310
I started the body work on my car a couple years ago and never really got around to finishing it. The main reason being is the pain in the *** dent I have right over the gas cap I couldnt get it perfectly straight so and I don't want to paint the car until the body is perfect. I plan on having a professional fix it, but would it be easier to just shave it?
Attached Thumbnails Should I shave my gas cap?-01002.jpg   Should I shave my gas cap?-05001.jpg   Should I shave my gas cap?-04002.jpg
Old Mar 20, 2007 | 02:42 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
if you shave it, where are you gonna put the gas in?? you cant run a pipe inside the car cause thats just dangerous..
if worse comes to worse, try to make it as straight as possible and load it with bondo.. i'm sure a pro body guy can make it straight.. get a quote from them..
Old Mar 20, 2007 | 03:59 AM
Car: Z28
Engine: 310
It's already been loaded with bondo by me and that's the best I could get it. You're probably right about a professional being able to fix it, but it seems like it'd be difficult since the dent is actually around the gas cap.
Old Mar 20, 2007 | 04:26 PM
5678TA's Avatar
Car: 1984 Trans Am
Re: Should I shave my gas cap?
well since you put it like that, you could consider a new quarter panel.. quite some work but it will fix your problem.. and be perfectly straight
Old Mar 20, 2007 | 04:41 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
You're just going to create headaches by not fixing the real problem... I'm at a loss to how you'd fill the tank though... you'd have to switch to a fuel cell or something along those lines.
rideon350's Avatar
A good shop could get it out. A pain in the @## to you but just another day at work for a good bodyman.
Old Mar 20, 2007 | 05:31 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Ever think of looking for a cheap gas cap on here or ebay? I wouldn't see a problem if there were a way to get gas in, but there's not much room to work with.
Old Mar 20, 2007 | 07:32 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Shave it. Looks way better.
Old Mar 20, 2007 | 07:40 PM
101jinx101's Avatar
Where did you reroute the filler cap to? (picture above)
Edit: nevermind, just visited your cardomain site. Kind of annoying to pop the hatch everytime you fill up though, isn't it?
Old Mar 20, 2007 | 08:24 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Car isnt DD. Its a week-end toy and its not annoying, and adds to the cool factor
Old Mar 20, 2007 | 08:29 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Put a fuel cell in it and shave it :P
Old Mar 21, 2007 | 02:37 PM
bigpoppa08's Avatar
Car: 82 Camaro
Engine: 305 SBC Carburetor
Transmission: TH-350
if u got a little time on ur hands u could probably use a slide hammer and pop it out further and then may be use a metal body filler instead of bondo its a little more expensive but for bigger stuff its better
Old Mar 22, 2007 | 01:55 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Here is mine:
Old Mar 22, 2007 | 08:40 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Looking good Denis!
Old Mar 23, 2007 | 04:51 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Or you can shave it form the side and use a caprice gas tank to route it behind the license plate. Not saying it would work though, without alot of work at least. I started a topic a while back about doing this such thing in the fabrication forum and it concluded that it would be more work than it would actually benefit. Would look trick though.
Old Mar 23, 2007 | 05:03 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
i dont see how it would work routing it to the plate area, its lower on the bumper then a on a caprice. kinda hard to pump gas against gravity. ive seen some cars where the gas cap is behind the tail light, thats a cool mod... too much work for me tho
Old Mar 24, 2007 | 07:59 PM
pairtoe's Avatar
yeah if you route it to behind the plate you sttl have to worry about the hatch, and it will still have to be modified to run right through the middle of your trunk area. just leave it where it is and try one of those alluminum or billit cas cap covers. ive nver seen one of those on a thrid gen.
or even better find a way to rig it up so that you can put the gas can on the outer part of the car, like on the old chargers or vipers.
Old Mar 24, 2007 | 08:08 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
It would look good under the licence plate, Torino's had a nice setup with it being under a gas door in the back, here's a pic. It would be alot of work to put it under the licence plate, but might be worth it.
Old Mar 24, 2007 | 09:37 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You could easily reroute the filler to behind the tail light and make it hinge out.
If you wanted to get all fancy you could make it an electronic hinge.
like this...
http://www.superchevy.com/technical/..._25/index.html
Old Mar 25, 2007 | 11:04 AM
trigger GTA's Avatar
Car: 92 TA vert
like this...
bingo. thats exactly what i did
the filler neck will come through the glove box in the back and there will be no need to open the hatch to fill the tank. the hole system will also be sealed from the cabin of the car to keep the smells out
Old Mar 25, 2007 | 11:40 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
hmmm i like the looks of that tail light gas filler...... maybe when i get braver ill attempt it. Trigger, is yours all together and working?
Old Mar 26, 2007 | 06:02 AM
Car: 92 TA vert
what you see is how it is now. i still need to get some kind of acuator to make it open and close. and i have to add the filler neck part
Old Mar 27, 2007 | 04:23 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
you should fab up some hatch pulldown style motor or firebird headlight style motor for the light.
i think something with a secure up/down position would work best.
Old Mar 28, 2007 | 08:46 PM
Car: 92 TA vert
already done that too. going to use a small 12V accuator to open and close the light with a flip of a switch
Old Mar 28, 2007 | 08:48 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
sounding nice, lets see some pics when its together
Old Apr 18, 2007 | 12:50 AM
84350twinturbo's Avatar
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
i shaved mine i still have to paint the car but heres what it looks like with primer but not sanded yet
Old May 15, 2008 | 09:15 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Gonna bump this thread. Im abougt to primer my car. I already have the fuel cell mounted in my hatch. And this go me to wondering how hard is it to have the gas cap? And whats the best way to do it?
Old May 20, 2008 | 04:02 PM
madhatter's Avatar
have ever done any sheet metal work before. it is like adding a patch panel, cut a panel to fit and start tacking it in place, grind welds and bondo, it would be similar to patching up floor pans, minus the bondo. i will let you know how bad it is to do when i finish swaping the roof on my car
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1992 Trans Am
May 10, 2023 07:19 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
