How do I fix this ?????
Old Mar 21, 2007 | 06:58 PM
ryanz53's Avatar
Car: 84 Camaro
Engine: 81 oldsmobile 307 5.0L
Transmission: 700r
Axle/Gears: 3.75
Hi guys.
So I bought a second camaro last week.
for only $50.00 !!!!!!!!!
it had no motor or trany.
No problem, I had 305 HO and t350 trany in my garage.
The body is good except for this particular area I attached.
The bottom is good except for a small hole in floor (front passenger side)
Can anyone guide me through repairing this without replacing the quarter panel.
I want to learn, learn, learn.
I want to see what I can do with a fifty dollar car.
will post more pics
Attached Thumbnails How do I fix this ?????-dsc00007.jpg   How do I fix this ?????-dsc00008.jpg
Old Mar 21, 2007 | 07:00 PM
ryanz53's Avatar
Car: 84 Camaro
Transmission: 700r
Axle/Gears: 3.75
more pics
more pics
Attached Thumbnails How do I fix this ?????-dsc00009.jpg   How do I fix this ?????-dsc00010.jpg
Old Mar 21, 2007 | 07:03 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: How do I fix this ?????
Quick question: can you weld?
Old Mar 21, 2007 | 07:09 PM
ryanz53's Avatar
Car: 84 Camaro
Transmission: 700r
Axle/Gears: 3.75
yup.
Old Mar 21, 2007 | 07:46 PM
jay92,85,79's Avatar
Car: 85z28,
Originally Posted by ryanz53
yup.
pretty easy fix than. Cut out all the rust. The outer wheel house u should be able to make with sheet metal. Than ether get a 1/4 wheel open section.Or make with with sheet metal to. Before u weld every thing up get some rustmort ( or some kind of rust converter) To put on the rust inside the will house. Than use a good welding primmer. Get it close to the right shape than finish with bondo. Sorry don't have any with just the metal welded in
Attached Thumbnails How do I fix this ?????-rust.jpg   How do I fix this ?????-quterl1.jpg
Old Mar 21, 2007 | 08:59 PM
ryanz53's Avatar
Car: 84 Camaro
Transmission: 700r
Axle/Gears: 3.75
how do I shape the quarter open section with sheet metal.
I want to stay away from buying pre fab because I want to learn how to do it myself.
thanx.
I'm not worried about welding it up. although not so crazy about thin metal. Don't want to burn through.
Old Mar 21, 2007 | 09:16 PM
ryanz53's Avatar
Car: 84 Camaro
Transmission: 700r
Axle/Gears: 3.75
how would I produce this using sheet metal ?
Old Mar 21, 2007 | 09:30 PM
Car: 85z28,
The sheet metal will not perfect. U can use smaller pieces weld tap tap weld tap(with a body hammer) What i did on someone else car was Used a fender wheel lip. U can get a fender pretty cheap at the junk yard. And the shape is about the same. U will have to hammer and dolly it. Than to make it perfect use filler to get your line.. the only way to do it right is to weld it. U could use rivets but would not suggest doing it that way.. Practice welding on the fender u buy.Before u weld on the car
Old Mar 22, 2007 | 03:00 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Best thing to do would be to go to a salvage yard and cut a section out of a quarter panel and use that to tack in place. After tacking it fully weld it, grind it and prime and paint.
This route requires less time and fabrication. Good luck.
Old Mar 22, 2007 | 04:14 PM
Stephen's Avatar
Car: 87 GTA
If you are wanting to fab the piece out of flatstock, good luck finding somebody to show you the ropes.
Like leading (pronounced leding)...bondo has replaced it, and there is almost nobody left that knows hoe leading is done.
Save a LOT of time and aggrevation...cut a good piece off a junkyard car, and weld it on. Sheetmetal welding is FAR from standard, 1/8"...1/4"...etc., metal though.
Old Mar 23, 2007 | 10:56 AM
ryanz53's Avatar
Car: 84 Camaro
Transmission: 700r
Axle/Gears: 3.75
thanx guys.
I decided to the easy was.
I bought entire quarter panel replacement from BNC here in Montreal
for $100.00
But thanx for your help.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
