Drivers side window moving slowly/locking up...
Old Mar 22, 2007 | 05:51 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
Little problem with my driver side power window. I realize this is fairly common on our cars.
My driver side window, after not using the car for a while, seems to go up/down like pretty normal, though a bit slower than the passenger side. However, if I keep rolling it up/down enough, it will eventually stop going completely and I will have to wait 30 seconds or so until it will move again, and even then it will just budge a couple of inches, then lock again.
My questions:
1) What, specifically, is the cause of this failure (and thus, what part do I need to replace) and where should I buy it from?
2) What is involved in doing this, and do you think I can tackle it myself? I am no expert on body stuff at all.
Thanks.
Old Mar 22, 2007 | 06:05 PM
Subnoizebro's Avatar
Car: 1987 Z28 Camaro
Transmission: 5speed
Axle/Gears: 3.08
Re: Drivers side window moving slowly/locking up...
I have this same problem on my 87 Z28. Except its both windows move pretty slow. I was told the soleniod(motor) for the power windows are just getting old and worn out. Im not sure if its true or not but it sounds legit. I suggest to have the motors replaced or refurbished. Also check to see if you battery is having enough output to run everything.
Old Mar 22, 2007 | 06:38 PM
smartman__007's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
Entirely legit. The innards are worn out and what's happening is their drawing more current to do the same job, but that causes the internal breaker to overheat and stop the current until it cools off sufficiently. Replace the window motors and lube EVERYTHING that moves with white lithium grease.
Old Mar 26, 2007 | 09:49 PM
JungleMan's Avatar
Engine: L03 :(
So should I just replace the window motor? Or do I need to replace other random electronics? And how would I do this? Thanks
Old Mar 27, 2007 | 07:49 AM
Car: 1990 Camaro RS
Axle/Gears: 3.08
I'd replace the window motor. It would probably be a headache to replace the internal components trying to find the culprit. Theres a link in the tech articles to a site that has diagrams and pictures. http://www.p71interceptor.com/thirdgen/powerwindows/ It's used to put power windows into a manual window car but the basic principles apply. Take the door panel off, find the rivets holding the motor in, get something to hold the gears so the spring doesn't let the mechanism unspring and destroy something, reverse for installation.
Old Mar 27, 2007 | 03:58 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
There's also a fix somewhere on this site
having to do with making them roll up and down faster than they do. Something to do with the motor wiring.
Later
Old Mar 28, 2007 | 04:16 PM
Axle/Gears: 3.08
you might as well just replace the motor...
www.ecklerscamaro.com
go there and search for your year in motor replace ment...
Old Mar 29, 2007 | 12:17 AM
Kandied91z's Avatar
definately the motor and definately a paint in the ***. one of the few things i pay someone else to do because it's very frustrating for me.
motors should be 30-40 and roughly 100 or so for labor or however long it takes you. you'll need to drill out the rivets unless it's been previously replaced and the person mounted it rivetless. you'll then need to re rivet the unit or use another fixture to attach it. there is nothing else electrical in the door for this.
our window glass is heavy... end of story. pita, good luck.
Old Mar 30, 2007 | 10:09 PM
russianneckred's Avatar
Car: 91 RS from coast to coast!
I got the same problem on my 91 Firebird, I took the panels of and it looks like replacing window motor is a major PITA... my repair guide suggested I seek professional help... (i have a 92 part car with working window motors...)
Should I really go to a mechanic or does some one have good detailed instructions on how to do it yourself? Jungle Man any luck?
Old Mar 30, 2007 | 11:30 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
It's not as hard as it looks. I took my car somewhere and they really screwed my door up. They cut holes in the door, big holes, and one was where my cup holder screwed into. Look at a diagram of where the rivets are, there is a page on this site that shows them. Unplug the motor first, then drill the rivets out. If you go to AZ or Discount, motors are about $65. If you go to a GM Dealer they run about $190 if I can remember correctly. I'm not sure how long AZ or Discount motors will last but i've had mine for about a year and it's still going up and down fine. This is my second Auto Zone window motor as my first one went out when I was rolling my window up and some dumb chit decided to try and push my window down to keep from going up. My drivers side window is doing the same thing right now but i'm going to go with the GM Motors because they last 15 years.
Old Mar 31, 2007 | 01:55 AM
MavViper's Avatar
Ya, it's the motor that's burning out. My buddy's Blazer has the same problem with one of his windows.
Old Apr 24, 2017 | 02:52 AM
hapbobg's Avatar
Good morning, Anyone have a good. I just thought of it and went to "youtube" and there it was repairing window for 1991 camaro.
Old May 16, 2017 | 02:03 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I did this last year on my car. Both sides. It definitely isn't the easiest thing to do but iv had far worse window regulators and or Windows iv done. Hardest part was drilling out the rivets. The motors I got (wanna day from o'riellys ) came with bolts and nuts to replace rivets. Well worth it! Windows go up and down alot faster. Also I use to have to open the doors and finish rolling them up so the wouldn't leak. Now they roll all the way up.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
pfsteichen
Feb 9, 2016 06:59 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
