z28 ground effect removal
Old Mar 25, 2007 | 10:23 PM
redZ's Avatar
Car: 1986 Z28
Transmission: WC T5
Axle/Gears: BW 9 Bolt 3.27
hey everyone just new here, wondering if anyone would know how the rocker panel ground effect comes off, have all the screws out from the underside and inside the door, what type of clip holds it against the car if any. just real cautious dont want to break anything any help would be appriciated thanks
Old Mar 28, 2007 | 03:09 PM
MG66Biscayne's Avatar
Car: 1984 Z28
Engine: L69
Re: z28 ground effect removal
Hello, I'm new here too with the same question as redZ. Just bought an 84 Z28. I need to remove the rocker ground effects for repainting. Is there a trick to removing them so they are not damaged? Look forward to hearing from those with experience.
Thanks,
Mike
Old Mar 28, 2007 | 03:44 PM
thatpontiacguy's Avatar
Car: 1986 Firebird (sold 1985 T/A)
Engine: 2.8L (miss my V8)
Transmission: auto (next one will be standard)
Not a Camaro owner myself...more of a firebird/trans am owner...but it seems to me that there may be more screws inside the front and rear wheel wells. My old trans am GFX came off quite easily once I had removed all visible screws, and eccentially camaro GFX should be the same. I'm sure someone will pipe in if I'm wrong. Best of luck to you.
-Caleb
Old Mar 28, 2007 | 08:30 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Door piece.. You have 5 nuts. 3 behind the door panel, 1 on each end of the door in the jamb.
Rocker piece...
A. You have about 7-8 screws under the car.
B. You have 1-2 nuts depending on year that is behind the trim in the rear, down low. you have to pull the bottom rear of the seat out, cut thru some rubber air seal stuff. This one is a bitch.
C. 2 nut/bolt ones going thru the front fender. Easiest to access via removing the plastic fender liner and reaching back in.
D. 4-5 screws in the door jamb area. You should easily see these.
Front chin spoiler..
Depends on the year. The 91/92 style has 4 spring clips where it meets the fenders. Then about 12 10mm bolts holding to the front nose.
rear fender pieces..
I have yet to remove. Appears to be some screws on bottom side, and some nuts via the "trunk"
Rear bumper..
handfull of plastic clips on bottom side. You pull the pin in the middle to remove the clip. Then via the "trunk" you have 3?? nuts on each side. You have to remove the tail lights and theres some more plastic clips. Then its also bolted to the same place as the licsense plate flip.
Old Mar 28, 2007 | 09:03 PM
Car: 1984 Z28
Engine: L69
Great information. Thanks Dale!
Mike
Old Mar 28, 2007 | 09:25 PM
redZ's Avatar
Car: 1986 Z28
Transmission: WC T5
thanks alot everyone may have saved me from trying to find a replacement, advicing is appriciated.
well it appears i cant type or proofread sorry for posting again but had to mention it
Old Mar 28, 2007 | 09:54 PM
Dale's Avatar
Engine: 350 S-TPI
Let me know if I have my screw/bolt counts off. But that gives you the general idea of what is where and how it needs to be tackled.
Old Mar 28, 2007 | 10:07 PM
redZ's Avatar
Car: 1986 Z28
Transmission: WC T5
yeah thanks man i had all the others off i really just didnt want to break these so i figured i'd ask before i tried anything else, i just didnt realize the ones inside the car in the back beside the back seat, and yeah your bolt count is pretty well right on
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
