Do you have pictures of POR 15 applied ?
Old Apr 7, 2007 | 01:30 AM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Does anyone have any pictures of por 15 after it has been applied? I would really like to see what it looks like. THANKS
Old Apr 7, 2007 | 08:06 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
Re: Do you have pictures of POR 15 applied ?
check my cardomain , i have pictures when i used it on my built rear end in my ta .
Old Apr 7, 2007 | 09:17 AM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Here you go.. just in the middle of painting my rear end
Attached Thumbnails Do you have pictures of POR 15 applied ?-dsc01042.jpg   Do you have pictures of POR 15 applied ?-dsc01043.jpg   Do you have pictures of POR 15 applied ?-dsc01045.jpg
Old Apr 7, 2007 | 12:34 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
heres a few of the wheel wells I did.
Attached Thumbnails Do you have pictures of POR 15 applied ?-sspx0529.jpg   Do you have pictures of POR 15 applied ?-sspx0546.jpg
Old Apr 7, 2007 | 04:18 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Check out my Car domain page. i did my rear end with it as well..
Old Apr 7, 2007 | 05:55 PM
NomadTA's Avatar
Car: 11 F350 CC DRW Dsl
You're going to have to cut back on the Guiness, all your pics are a bit blurry, either that or it's the Crown & Ginger I've been drinking.
Old Apr 7, 2007 | 11:25 PM
Orinackra's Avatar
mmm, i do like me guinness....alot. But this time I have to blame my phone, its crappy camera is the only thing i have right now.
Old Apr 8, 2007 | 09:49 AM
trigger GTA's Avatar
Car: 92 TA vert
i thinned the por and shot it through a paint gun.
http://www.ccfbg.com/projectcar/EPSN0357.JPG
Old Apr 8, 2007 | 04:11 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Just be advised that if you decide to spray the POR, you need some seriously professional respirators. That stuff is nasty.
Old Apr 8, 2007 | 10:02 PM
JB22's Avatar
if you go to my website www.jskme.com and sift through my pictures there is some of my rearend and k-member
Old Apr 9, 2007 | 10:21 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Here is the rear that I painted:
Here is the engine with their high temp engine enamel:
**Forgot, the headers are painted in their hi heat silver as well.
Old Apr 9, 2007 | 02:04 PM
Car: 1991 Camaro RS
Hey spartyon, did you spray or brush that rear end? It really looks good.
Old Apr 9, 2007 | 07:49 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Used a brush for everything. The header paint needs a caution/warning label. After sitting for about 30 minutes it started eating through the plastic paint cup I had. That was some nasty stuff.
Old Apr 9, 2007 | 07:57 PM
JB22's Avatar
Its so thick that it evens itself out as it cures. You cant even tell that you painted it on with a brush.
How has the header paint held up?
Old Apr 9, 2007 | 10:19 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Old Apr 11, 2007 | 04:25 PM
83 Crossfire TA's Avatar
Any pictures after it’s been sitting around a while? It’s supposed to fade when exposed to UV light, I wonder what that looks like.
Old Apr 11, 2007 | 08:06 PM
JB22's Avatar
I think the 2 above pictures show it a little bit. you can see the rust a little bit through the paint under the rear coil spring.
Old Apr 11, 2007 | 08:20 PM
Car: 2012 Corvette
Engine: LS3
What rust? Those pictures were taken only a few days after it was painted and it still looks exactly the same, no fading.
Old Apr 11, 2007 | 08:22 PM
JB22's Avatar
It looks like pitted rust in the picture, but maybe its just airbubbles
Old Apr 11, 2007 | 08:36 PM
Car: 2012 Corvette
Engine: LS3
Oh I see what you're talking about. That's dirt. There was a lot of it up in the spring pocket and on the coil spring.
Old Apr 18, 2007 | 12:13 AM
84350twinturbo's Avatar
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
!!!!!!!!!!!!!!!!!!!!!!!!WARNING ABOUT POR 15!!!!!!!!!!!!!!!!!!!!!!!!
unless you have a full respirator system do not DO NOT use a spray gun on it it will get into your lungs and set and cure in 10 min and you are dead use a brush.
on a lighter note
you do not have to clean the rust off of the part that you want to paint por 15 likes to adhear to rust it doesnt really like to stick clean surfaces. ill take some pics of my rear end and front wheel wells that i did to post the pics on here and i painted over rust and i think even a little dirt
Old Apr 18, 2007 | 06:44 AM
Car: 1991 Camaro RS
Yeah I have no intentions of spraying it on. Most poeple brush it on so thats what I will do. I just bought my por15,marineclean and metal ready the other day so as soon as I am done prepping the underside of my car I'm gonna paint her up. Thanks for the warning though. Lets see those pics?
Old Apr 18, 2007 | 07:20 AM
AC's Avatar
AC
Car: Used to drive a camaro
POR Engine Paint and then normal POR black for suspension & rear end.
https://www.thirdgen.org/forums/engi...-383-done.html
Attached Thumbnails Do you have pictures of POR 15 applied ?-picture-170.jpg
Linson
Sep 21, 2015 01:08 PM
Randomtask2
Sep 7, 2015 05:06 PM
Street Lethal
Sep 7, 2015 01:09 PM
Strick1
Sep 6, 2015 02:21 PM
