Tie-rod Issue
Old Apr 27, 2007 | 04:50 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Tie-rod Issue
Got some new tires the other day and wanted to get a wheel alignment. The problem was there was no clearance between the tie-rod end and the "center bar" it connects to on the passenger side to make the necessary adjustment. The two bars were almost touching. However, there was about 2-3 inches of clearance on the drivers side. As a result, the shop could not center the steering wheel to the two front tires. The car rides fine (no pulling or wobbling). It seems like something was not installed correctly. I don't know the correct names for the parts so please bear with me. Any suggestions on how to correct this?
Old Apr 27, 2007 | 08:10 PM
Pukka's Avatar
Re: Tie-rod Issue
OK here is a better explanation.
I have almost no space (within the adjsutment sleeve) between the inner and outer tie-rods on the passenger side...they are almost touching. However the driver side has about 2 inches of sleeve space between the two tie rod ends. It seems like the center link is not lined up properly. Anyone know how to fix this?
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
