firebird to trans am spoiler swap
Old May 4, 2007 | 12:42 AM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
does the trans am spoiler bolt into the same location as the trans am spoiler?
my car is an 86 and so is the trans am spoiler. if not will i just have to drill more holes? or completely differant ones?
Old May 5, 2007 | 02:18 PM
Engine: 2002 Ls1
Transmission: t-56
Re: firebird to trans am spoiler swap
anyone???
Old May 5, 2007 | 02:54 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
If you are talking about the pedestal spoiler on the Firebird and the aerowing(wraparound design) on the Trans Am, then no. You will have to drill some holes and fill some holes. Why not switch the entire hatch?
Old May 5, 2007 | 03:40 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
you don't need to swap the "hatch" just the decklids. just unbolt the 10mms from under the interior panel and use a putty knife to separate the decklid from the glass. do it on a hot day so the adhesive is more plyable. use windshield adhesive to stick it back together.
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Randomtask2
Aug 13, 2015 01:57 AM
mizz0313
Aug 12, 2015 06:45 AM
