Removing 82-84 Tail Light Bird Emblem?
Old May 12, 2007 | 11:19 AM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
I recently came across a 1982 tail light center piece which has the gold bird. The bird itself is in mint condition, but the rest of the piece is cracked/broken. I'd like to remove this bird and put it on another tail light piece that I have. Has anyone successfully done this before without breaking the bird?
Thanks,
Joe
Old May 12, 2007 | 11:01 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Removing 82-84 Tail Light Bird Emblem?
Everyone I have removed have broken (junk yard emblems) but if I were you I would try to heat it up with a hair dryer and go slow.
Old May 13, 2007 | 08:45 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The heat sounds like a good idea. But getting all the way down the side of it and underneath it with something very thin(like the end of a tiny flathead screwdriver that's been filed down super thin) would seem to be the key to prying it up and out.
The bird is about 1/8" thick. And most people tend to chip the edges of it because they don't use something thin enough to get all the way down under it before they begin to pry it up. So they pry from the edge and not from the bottom.
So using something super thin and the heat, together, along with working very slowly, would prolly work.
Old May 13, 2007 | 09:23 AM
cdoyle's Avatar
I was just going to say this as well, use something like a Jewelers screwdriver. Those are very tiny and if you heat it up. You should be able to slowly start peel it off.
Old May 14, 2007 | 01:53 PM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
I have removed several birds. I simply submerge the entire piece in hot (steaming) water for about 10 or 15 minutes, with the help of a very tiny screw driver you will be able to pull the bird off with no trouble.
Start prying at the wing tips and bottom, but be very gentle they are the weakest point.
Old May 23, 2007 | 11:12 PM
Hazardis's Avatar
I would use the boiling water , with the dull edge of a long xacto knife blade .. its thin enough , just go slow & easy ..
Haz
Old May 23, 2007 | 11:50 PM
LIL BASTARD's Avatar
Car: 1985 Berli
Axle/Gears: stock Berli
Since the light is broke. Why not cut the bird out with a coping saw or another fine saw? That way you dont have to pry up at all. Is it indented in, then you could get a better angle at it. my opinion
Old May 23, 2007 | 11:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Run a piece of fishing line under it, with some heat? I'm not even sure what the piece looks like, but that might help you wipe away the glue without cracking the bird.
Old May 24, 2007 | 05:45 AM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Yeah id try the hot water, should make the glue nice and soft.
How I wish my bird looked that good, She has had her wing cliped by some F***head trying to steal it off my car.
Old May 24, 2007 | 07:15 AM
Blackknight's Avatar
Another way to do it is heat it up with a heat gun, let it colden again and follow those steps a couple times, will make the glue brittle and will stop sticking as good.
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
