weatherstripping problem.
Old Jun 10, 2007 | 07:25 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
im missing some weatherstripping. its in window area right where the T-top meets with the arm of the car. like if u were looking at the car from the side the left part of the t-to and window. anyhew, does anyone have any good solutions or will weatherstripping from autozone work? also my t-tops r leaking right in the back middle in between both t-tops. i believe caulk will work for that.
Old Jun 10, 2007 | 10:48 PM
duesterj's Avatar
Car: 1988 IROC-Z
Engine: 5.7 350
Transmission: Automatic
Re: weatherstripping problem.
Check out the tech Bulletins on the website, I know I have read some good tips for fixing T-top leaks.
Old Jul 21, 2007 | 03:53 AM
ATCharming's Avatar
Car: 2000 SS
Transmission: a4
a friend of mine created a writeup on ls1.com about ttop leakage (he has an 86 iroc, was givin me some advice)
he said that if you take off the ttops, peel the stripping up slightly (not off, just enough to get under the rubber) and use some caulk, it will fix many problems.
Old Oct 7, 2009 | 08:24 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
mcbitchman
Sep 29, 2015 12:32 AM
383cam
Sep 9, 2015 06:01 AM
