Anybody know how to remove the steel lip around windows?
Old Jun 22, 2007 | 06:32 PM
PROPHET69's Avatar
Car: Modified 1985 Z28
Engine: 355 Carbureted
Transmission: TH350 Turbo
Ok, people, all that's left for me to strip right now... are the door parts... and Holy F**k. Lot's of issues here trying to remove all the weather stripping. First question, have a hardtop and around the roof edges, there's a steel lip, then on the inside, the weatherstripping. Can the lips even be removed? And how do we remove that weatherstripping without damaging it? I need to remove it to dissolve the old paint that last idiot put on it, and of course moisturize it.
And here's another one, to remove the door's outer weatherstripping, it seems as if I'd have to remove the power windows (which looks crazy complicated) to get to the screws which holds the stripping. AND also must remove the side mirrors which blocks other side screws. Has anyone ever removed the door stripping otherwise?
Thanks again oh mighty third gen gurus.
Old Jun 23, 2007 | 02:04 AM
PROPHET69's Avatar
Re: Anybody know how to remove the steel lip around windows?
Nevermind, Steel lip is part welded on, won't happen. But anyone know about the weatherstripping? Still having a Hard time Taking it off
Old Jun 23, 2007 | 09:34 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Steel lip? Are you talking about the weatherstripping channels that go around the window on the body side? Those are removable with a screw driver once the weatherstripping has been removed.
Old Jun 23, 2007 | 09:46 AM
PROPHET69's Avatar
Great! I could of sworn it was attached to the body when I looked last night. I'll give that another try in that case.
Old Jun 24, 2007 | 12:02 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
take out the weatherstriping, then you can unsrcrew the weatherstrip channel.
the drip rail is welded on, but its weak.
a lil tack here and there.
i removed mine with a 5 in 1 painters tool.
looks so much more slick without that metal there.
Old Jun 24, 2007 | 12:12 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
hey you got a pic of it without the trim? i just take mine off
Old Jun 24, 2007 | 11:52 AM
PROPHET69's Avatar
I second that question, do you have a pic? I've never considered leaving it off.
Old Jun 26, 2007 | 02:54 AM
Kandied91z's Avatar
mine wasn't tacked in. few screws and off it goes... as for saving weather stripping... i've never seen it done unfortunately.
i would like to ask you a question. how do you moisturize paint or whatever your moisturizing on your car?
Old Jun 27, 2007 | 04:04 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
if you are talkin about the part that is along the window opening then that is easy. you know the triangle by the mirror loosen the nuts on it to get the remaining screw. i did mine in like 5 mins off with old and on with the new
Vintageracer
Jan 10, 2020 05:33 PM
dbrochard
Aug 30, 2015 05:56 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
