Wing Seperation Anxiety Syndrome
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
I have suffered this terrible burden of W-SAS since I got my 1983 Trans Am. I am scared to look in the mirrors or go through an auto car wash, and fear even touching it when opening the hatch.
My rear wing has seperated somehow. Seems the factory glued the top and bottom of the wing together and the glue has failed. I first contracted this disorder while going through the auto car wash for the first time in her. I was excited to get her washed up and my favorite part was coming at the end where the massive blowers make you feel like your going 300mph, as I approached the holy ground, suddenly I heard a terrible terrible terrible sound akin to a leather belt being held and snapped several hundred times per minute, and I stare agape in the mirror as my rear wing is committing suicide. For almost a minute I was in pure hell just waiting for her wing to come sailing through the hatch or worse, through the next cars windshield. Then the calm came over me as the tide of terror ceased, and I realized that she made it through the storm, and just a bit worse for wear, she was ok, but She's been hurt and needs my attention.
Ok enough of the drama crap, how the hell did my wing seperate, and how do I fix it? I tried using hot glue(the red glitter kind if you care to know...lol), but unfortunately the wing is black so I'm sure you can assume well how that went. Is there a way to get the rest of the glue holding it to release so I can clean it up and glue it back together the right way?
Thanks,
Frank
Thanks,
Frank
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Re: Wing Seperation Anxiety Syndrome
soo.... next time just put it in gear hit the gas and get the hell out of there.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Sorry I dont know how to fix your problem but your post has thoroughly entertained me. Thanks!
Car: 1987 Trans Am
Engine: 355
Transmission: t56
maybe some auto strength double sided tape could work. or you could keep trying glittery hot glue.
Car: 87 GTA
Fiberglass wing? It sounds like, the sudden drop in temperature, between the hot water, and cooler drying air, caused that to happen. Never seen that happen before.
Car: 83 Trans Am
Engine: LT1 350
I think I am going to pull the wing off my 90 Bird and put that on her. Its white anyhow so it matchs better. The black wing with white paint was a bit wierd anyway.
Car: 1987 Firebird
Engine: 355
when i bought my car in december, i had the same problem, i brought it home. Luckily we had +3 degrees celicius (freezing is 0 degrees C) so i had just enough warmth to wash. I jacked up the rear as high as my jack would go, got out my hose, and sprayed it with water for a good 20 mins. Got all the little nooks and crannies, and kept rinsing till i didnt see salt wash out anymore. Worked well.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
the stock spoilers on an 83 trans am are extremely common and cheap. hit some junkyards or the classifieds and find one locally. I'd expect to pay about $15.
