Headlight motor question
Old Aug 15, 2007 | 10:44 AM
reviver90's Avatar
Hi I have a question about the difference in the motors between say a 86 firebird and a 90 firebird. I personally have a 90 but I bought a headlight and headlight motor out of a 86 now I know that the headlight and bracket will all fit, and I also know that the 86 has a three wire motor and my car has a two wire motor. I tested my motor and the gray with the black strip is the hot and the green is the ground. What are the colors of the other wires coming on my new motor and what is the third wire for? I am thinking I will just cut off the two wire connection from mine original motor and splice it onto the new motor for the power and ground, I am just curious what that third wire is for. Any help would be greatly appreciated.
Thank you,
Kenny
Old Aug 15, 2007 | 11:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Headlight motor question
I've seen a few cars in the junkyard that have been Jerry-Rigged as you describe. My 88 Formula had a 3-wire motor swapped for one of the 2-wire motors. I can tell you the two systems are not compatible at all. It simply won't work. The three wire motor can't be made to work in place of the two wire unless you comletely re-wired the car. I don't know why you'd want to go back to the older inferior headlight motors though.
Lon
Old Aug 16, 2007 | 06:23 PM
reviver90's Avatar
thanks man not exactly what I wanted to hear but thanks for the reply
Old Aug 16, 2007 | 11:06 PM
lonsal's Avatar
Well, That may be true. However, wouldn't you want the bad news up front before you wasted your time?
Lon
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
