Flat black Urethane splotchy !!!
Old Aug 20, 2007 | 07:26 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
This was my first paint job (rookie garage painter). It was a Urethane and medium hardner ( 4:1 ) flat black. It came out VERY uneven with stroke lines and some areas flater than others. I useds a $100 hvlp gun i got at carquest (1.4 tip)(6cfm required 10psi) my compressor SAYS 6.5cfm@40psi but it ran ALOT while i was painting...Im not looking for, or expecting a near professional job, just nice even old school Hot Rod flat black thats not primer,but I've had better results from a rattle can...
Given the above info, any guidence or suggestion for the re-paint would be GREATLY appreciated.
Ps The tech sheet said it could be reduced with the supplied reducer but i chose not to use it.
Old Aug 21, 2007 | 03:36 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Re: Flat black Urethane splotchy !!!
Noboby has any suggestions....
Old Aug 21, 2007 | 04:32 PM
Moonlight's Avatar
Car: 1991 Z28
Transmission: 4l60e
Yea i had the same problem when some guy rubbed in a parking lot. I didnt use primer but primer does make the paint stick better. I used a rattle can that was a perfect match to my car, i painted too close and it ran like ****. so i had to sand it back down again and paint further away and had to paint over the same area 2-3 times over because i was further back, but it came out even and clean. So i would suggest try doing what i did and make sure ur spraying fairly quickly not holding the spray gun in the same area for too long.
Old Aug 21, 2007 | 06:27 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Technique. You want 50% overlap and consistent gun speed and distance. That will take practice.
gta892000
Aug 11, 2019 11:16 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
m00n420
Sep 11, 2015 02:39 PM
Ironhead38
Sep 7, 2015 02:26 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
