Any pics?????
Old Aug 25, 2007 | 12:20 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Any pics?????
Of where they cut a hole in their car to make an acces hole to the fuel pump. I have a 88 camaro and I am not sure of where to exactly cut my hole. any pics are helpful
Old Aug 27, 2007 | 06:47 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Any pics?????
Don't cut the hole.
I cut the dreaded hole (10"x10") in my car (but welded it back, ground and painted it) and it didn't do me any good. I had to drop the tank anyway. I don't know if yours is like my bird, but it had rigid fuel lines that wont bend enough to get the pump out...unless you basically hack most of the rear panel out.
If I ever have to change a pump again, which I'm sure I will on the next project I won't even consider hacking out the sheetmetal.
It's your car, do what you want.
Just my
Old Aug 27, 2007 | 07:48 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: Any pics?????
why hack job it? you will spend just as much time to do it correct.
Old Aug 27, 2007 | 11:54 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Any pics?????
WRONGGGGG. hahah i did it in one night. It was super easy. Dotco is great to cut the hole. Then you use either tin strips or wire cutter to cut the lines. Once they are seperated you cut the lines with a pipe cutter. nuff said
Old Aug 28, 2007 | 12:07 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: Any pics?????
How did you seal your hole up??
I hope the hack job doesnt start a leak.
Old Aug 28, 2007 | 12:14 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Any pics?????
No. it hasnt leaked yet and will not. I will be sealing up the hole now tomorrow.
Old Aug 28, 2007 | 11:57 AM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: Any pics?????
The only thing I would be woryed about is fuel leaks there is over 50 psi there on a tpi so I wouldn't trust hose clamps and fuel line. The only way I would do it is flareing the lines but I'm sure thats too much of a hassel for someone who didn't want to drop the tank to change a fuel pump. I know it sucks but it only takes about 3 hours to do it right.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
