The start of my LED conversions
Old Jan 6, 2008 | 07:21 PM
  #201
cdoyle's Avatar
Re: The start of my LED conversions
Just started on it today, got about 6 rows done on the first brake section.
Those one for the group buy, I don't see anywhere what type of LEDs or the number they are using etc. Is it a retro for just the turns, or everything?
If they use actual superflux, they'll cost way more then 234.00. If they just cheap out and use 5mm LEDs or superflux knockoffs, I would no way spend that much money on them.
I'm curious to learn more about them tho.
Old Jan 6, 2008 | 08:39 PM
  #202
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
not really sure I e-mailed the one that started the thread to learn more about it.
Old Jan 7, 2008 | 10:11 AM
  #203
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Originally Posted by cdoyle
Well I couldn't find the diagram that I first used when starting this type of stuff, but I found one similar.
Just ignore the resistor values, and my array used 5 LEDs per string instead of 4.
But this should give you an idea how to wire it up.
I hate to a pain in the butt. But could you come up with a parts list for each board with there size and dimesion of the board? Could you also do a schematic for each board?
Also in the picture above did you put the same resistor in the side panels to match the same dimmnes as the tail/brake panel? Did also use a diode in the side panel circuit?
I want to start doing this right away. Im only going doing the rear lights.
Old Jan 7, 2008 | 12:35 PM
  #204
ssean92's Avatar
Car: sold
very nice I like it alot
Old Jan 7, 2008 | 10:48 PM
  #205
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
How exactly did you remove the cover from taillights? I haven't looked at mine but I thought they were melted/seamed, or glued ?
Any UPDATED Video's? How much did it end up costing you?
Old Jan 9, 2008 | 01:29 PM
  #206
cdoyle's Avatar
the tail lights actually open up pretty easy, there are a couple screws on the top (they are covered by some screw caps.) Remove those, and the only thing hold them on are the the locking tabs on the bottom. So you just have to slowly pry along the top, and also on the tabs until they come apart.
I was really surprised how little there is, keeping these things together! The front turns tho, that's a different story. Those I had to get out the dremmel to get those open.
No real updates just slowly started working on the other side.
A few of you have asked to see a pic of the back of the boards.
Here is the one I'm working on now.
Old Jan 9, 2008 | 03:04 PM
  #207
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Wow very sweet dude, really clean looking and it looks a lot brighter.
the front ones look a bit to square just my you could put like two on the sides to give it a more round look just an idea but they still look sweet!
Old Jan 9, 2008 | 10:25 PM
  #208
Domminigan's Avatar
Car: 82, 82, 88, 91 Camaros, & 86 GN
I'd been thinking of doing something like this for a while, but I hadn't figured out how to place the LED's inside the housing. Excellent work!
Old Jan 9, 2008 | 10:31 PM
  #209
Domminigan's Avatar
Sorry, I double posted, and can't figure out how to delete the bugger.
Old Jan 11, 2008 | 08:45 AM
  #210
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Since I dont have the patience as cdoyle. I decide to design and purchase a couple made up pcb boards. So far I got the backup board and the tail/ brake board. I used 8mm leds for the backup board since that is what I already purchased and a set of superFlux Leds for the tail/ brake board. Here is drawings of both boards.
Attached Thumbnails The start of my LED conversions-tail-brake.gif   The start of my LED conversions-backup.gif
Old Jan 11, 2008 | 10:10 AM
  #211
jstoltz's Avatar
how much was it for premade boards? Post pics of yours if you get a chance.
Old Jan 11, 2008 | 10:34 AM
  #212
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Ok I should get my first set of prototype bords in a couple days. All this means is they are not coated and have no silkscreen on them to show were the componets go. There not cheap about $90 for a pair but ofcourse the more you order the cheaper they get and if you order 10 or more each board goes down by more then half. I should complete the back up lights in a couple days after that then I will work on the tail/ brake lights. I still have to design the turn signal boards and then I will have to come up with something for the side panel tail lights.
Old Jan 16, 2008 | 02:46 PM
  #213
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I have finished designing all the boards. Just waiting for the first two to get here to get started soildering them up.
Attached Thumbnails The start of my LED conversions-tail-side-1.gif   The start of my LED conversions-turn.gif   The start of my LED conversions-tail-side-2.gif
Old Jan 16, 2008 | 02:58 PM
  #214
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Im not sure if you would but I think you should look into getting these done professionally as maybe a new product for camaros?
Just a thought.
Now imagine if you bought all smoked red tail lights from www.klearz.com/camaro.html (its a group buy right now)
Custom Tail Lights Thread Found Here: https://www.thirdgen.org/forums/grou...ww-klearz.html
You would be able to install the STS to your LEDS and have a real badass design...you think?
Old Jan 16, 2008 | 06:20 PM
  #215
spddmn's Avatar
Car: 92 camaro rs
Engine: 305 5.0 v8
Transmission: stock automatic
Axle/Gears: stock
if u dont feel like doin all that work u can buy pre made ones that come in different colors and plug into your light socket they might not look as good as cdoyle's but they do a pretty good job
here is the site scroll down a little and youll find em
http://www.yearone.com/serverfiles/f...GO.x=16&GO.y=7
Old Jan 16, 2008 | 06:46 PM
  #216
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I just got my first set PCB boards today for the backup lights. I will post pics as soon a Im done with them.
Old Jan 24, 2008 | 06:30 PM
  #217
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I got my boards and finished the back up, turn and tail/ brake panels. All I have to do is order the side panel boards and I'll be done. I also odered the sockets to soilder the wires into them and then just plug them into the stock tail harness but soildering the wires in is a PITA. I think I may use weather pack connectors instead of the stock tail sockets.
Old Jan 24, 2008 | 06:32 PM
  #218
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
more pics
Old Jan 24, 2008 | 07:05 PM
  #219
cdoyle's Avatar
Wow those look great!
Doing it that way really makes this project easy!
thanks for posting the pics.
Hopefully I'll have mine done soon too.
Old Jan 24, 2008 | 11:52 PM
  #220
Yonash91RS's Avatar
Car: 1991 Camaro RS
Engine: 5.0L TBI 305
Axle/Gears: 10 bolt 2.73 open
can we get a recap on how you did those DerekKraese? and how much it cost? those look fantastic, and i really want a set lol
Old Jan 25, 2008 | 12:55 AM
  #221
DerekKraese : WOW!!! DAMN That looks AMAZING!!!!! How are you attaching the boards to the light assemby?
Old Jan 25, 2008 | 07:26 AM
  #222
jstoltz's Avatar
how are you doing the wrap around Derek? looks good so far. how much $$$ are you in so far?
Old Jan 25, 2008 | 08:12 AM
  #223
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I used expressPCD for the program to make them and ordered them through the program. Im going to use silicone to glue them into the housing. I still have a small bit of trimming to the baords and the housing it self to fit them in snug. Im doing the wrap around the same as cdoyle, Two small triangular boards I just ordered. It cost me alot cause I only ordered two prototype baords each so its puts it at around $40 a board, but if you order a good number of production baords the price drops lower.
Old Jan 26, 2008 | 10:09 PM
  #224
FerrMaro's Avatar
Wow! I'm so glad this mod is finally materializing into something a little more streamlined...Hopefully we can get an itemized list of exactly what to buy soon.
Old Jan 27, 2008 | 10:52 AM
  #225
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
There are only a few parts to buy but there are many different types of Superflux LED's. They are made by numerous manufactures and have different operating specs. I was considereng selling these but I would have to get a min. of 25 orders to set a price ot $265 for a set. That is still high and its a lot of work for a very little return. So I will just pass for now. If I could get a manufacture interested in my design that would be great but I dont think it will happen. So if anyone wants to try this them selves, I will gladly share my files that I made with expressPCB, but realize that if you do not use the same exact LED's I used it may not work correctly.
Old Jan 30, 2008 | 02:09 PM
  #226
thirdgenSS's Avatar
i want a set!
Old Jan 30, 2008 | 02:42 PM
  #227
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I want a set
Old Jan 30, 2008 | 03:55 PM
  #228
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
If anyone knows of a manufacture that would be ineterested in making these let me know and I will contact them. Otherwise I will not be selling these. Sorry.
Old Jan 30, 2008 | 04:51 PM
  #229
cdoyle's Avatar
I think DerekKraese has shown the most easiest way to make these yourself. Not having to solder in the jumpers between LEDs speeds a project like this up a ton.
To buy something like this premade, using true Lumileds superflux for the tail/brake sections would cost a ton of money. So making them yourself, you have the satisfaction of knowing that you're one of the few that have them, and also saved a ton of cash too.
Old Jan 31, 2008 | 04:36 PM
  #230
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Side panels now completed. Now all I have to do is mount the panels in the taillight housings and put them on the car and see how they look.
Old Jan 31, 2008 | 04:40 PM
  #231
cdoyle's Avatar
looking good
I have a few days off next week, and going to finish up mine too.
Still trying to decide how I want to mount the boards, not sure if I want to mount them back more into the housing, or closer to the lens.
I think closer to the lens gives a better look to the LEDs.
How are you doing yours?
Old Jan 31, 2008 | 04:50 PM
  #232
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I have to do some minor trimming to the boards and housings but Im going to mount them close to the lens. I like the LED look of it as well.
Old Feb 1, 2008 | 09:59 AM
  #233
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Hey DerekKraese, I just e-mailed www.clearcorners.com to see if they would like to be the company involved in getting these LED tail lights into production. I have talked with them before about this but now that you have everything they will need we might be able to get these put into production. I am awaiting the e-mail back. I also told them we are looking to just get the setup to install into the lenses ourselves, as many of us who want this are going to have the custom tails from KLEARZ. Sound good?
Well I gave them the URL to this thread so they should be checking in on it soon.
Old Feb 1, 2008 | 12:47 PM
  #234
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I also presented www.klearz.com an oppurtunity at this design. They might be the one for the job. They seem very interested...so we will see.
Old Feb 1, 2008 | 12:48 PM
  #235
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Ok thats perfect. Let me know what they need. PM if you need my info.
Old Feb 1, 2008 | 12:53 PM
  #236
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Since you know everything and I dont know squat on resistors and superflux leds and all that would you want to e-mail tina @ klearz?
Here is her e-mail. Just subject it as "LED CAMARO TAIL LIGHTS"
Tina info@klearz.com
Lets hope they are up for it.
Old Feb 1, 2008 | 12:59 PM
  #237
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Ok I emailed them lets see what they say.
Old Feb 1, 2008 | 09:16 PM
  #238
FerrMaro's Avatar
Ooo. This is exciting.
Old Feb 2, 2008 | 12:00 PM
  #239
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
Looks good guys. Percervierance....Has anyone talked about life expectancy? If they have, disregard.
Old Feb 2, 2008 | 12:16 PM
  #240
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
The LEDs that I used have a 100,000 hour life span.
Klearz does not have interest of making these at this time.
Old Feb 2, 2008 | 12:31 PM
  #241
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I am in contact with Spaghetti Engineering Enterprises at this time. They seem interested. They are about an hour from my home so hopefully it works out. So maybe with some emails to them that you are interested in having them made may help. info@spaghettiengineering.com
http://www.spaghettiengineering.com/
Old Feb 2, 2008 | 04:40 PM
  #242
cdoyle's Avatar
Wow, I can't believe this thread I started might actually spark enough interest to get a company to produce these!
That's pretty cool!
Old Feb 2, 2008 | 04:44 PM
  #243
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
If they produce a kit for this, I would be interested depending on price. I've always wanted to do LED taillights, but I hate soldering and I'm not very good at it when it involves circuit boards.
Old Feb 2, 2008 | 05:05 PM
  #244
FerrMaro's Avatar
I've emailed Spaghetti Eng. Judging by the pics on their website, I'm very impressed with the quality of products they sell.
Old Feb 2, 2008 | 05:44 PM
  #245
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
100,000 hours = 11 years....
This spaghetti place seems pretty good. Lets hope one of these works out. Might be cheaper than expected....
Old Feb 3, 2008 | 05:11 AM
  #246
riotcow's Avatar
Car: '06 G6 GT / '85 IROC(soon)
Axle/Gears: Stock
They both look great... Bu tI tend to like cdoyles more. Not simply for the fact that the leds line up with the grid better(not saying not centered, just the rows are evenly distributed into each grid, not behind the separations), but for that fact that he took the initiative to take on the project for himself.
I thought about a project like this when I had my rs...looks like something I'll have to do when I get my '85 Iroc. Then just for kickers and to be a little bit of an individual, I'll do the '98 Z28.
Oh and since they still dont make any non-coupe after markets for my G6, I'll fab me up some clear lenses and then do something similar to them ^.^
Old Feb 3, 2008 | 09:24 AM
  #247
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
I realized my LEDs didnt line after I had already orded my pcb boards. I was thinking about doing this project for a long time but just didnt know where to start. CDoyle had a great idea and I liked how his was coming along so I thought Id do the same thing. At the begining I had no itentions of doing this for others but I thought since there were so many people interested that I would try to make them for others but as soon as I got into it I realized the long process of making each board would take forever to actually make enough to sell and I just didnt have the time for something like that, plus I would almost get nothing in return for so much work. So thats why I thought a company that already make LED tailights would be interested in making these for the people that wanted them. But all in all I did do this project for myself.
Old Feb 5, 2008 | 07:25 AM
  #248
karl's-92'-z28's Avatar
Car: Too many cars
Thnx cdoyle for starting this mod, your the insparation
Old Feb 5, 2008 | 09:05 AM
  #249
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Just to let everyone know. Spaghetti Eng is going to start making these. I will let everyone what it will cost as soon as I find out.
Old Feb 5, 2008 | 09:16 AM
  #250
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Are they making just the circuit boards or the entire taillight assembly?
