Removal of headlight bracket...how hard is it?
Old Sep 28, 2007 | 01:08 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Hello all,
I recently wrecked my 92 Camaro and I need to replace the headlight retaining bracket or headlight panel. It looks like it's made of grey fiberglass, holds the headlights in position and runs across the front of the car.
How much trouble is that piece to take out? I have to get one out of a car in the junkyard and I want to make sure I take the proper tools. Do I have to take the entire nose off? Any help is greatly appreciated!
Old Sep 28, 2007 | 01:53 PM
cam383's Avatar
Car: 89 and 91 Camaro RS
Engine: 350ci TPI and 305ci TBI
Axle/Gears: 2.73 One-wheel wonder
Re: Removal of headlight bracket...how hard is it?
Its not too tough it just takes a bit of time.
You will have to remove the front bumper cover, at least thats the easiest way i've found. You need to unbolt the front ground effect from the fender then there are about 4 bolts that hold the front bumper cover to the fenders on each side. There are also 2 bolts on the center support along with a handful of small bolts around the hood latch area. there are also 4 bolts or so underneath the front. I just pulled one from a junk yard and it took me about 30-45 min to get it off. Bring a couple extensions for your socket (preferably with a wobble) also I found a 1/4" ratchet was easier to use since it's smaller and you can get more of a rotation out of it.
Good luck getting yours fixed
Old Sep 28, 2007 | 03:15 PM
chevybenz's Avatar
Car: 92 RS
Engine: 3.1 L
Transmission: Manual
If I remember correctly, my bumper removal kit had 10mm/11mm open end wrench, along with a 10mm long deep socket on a 1/4 inch socket wrench. I used the 10mm open wrench to get the highest nut on the right side if youre standing in front of the car. I couldnt turn it from underneath, so I had to turn it with like 45 degree rotation increments. Took a while. I took the bumper cover and headlight bar off as one peice.
I think the little screws that mount the top of the bumper cover V shape to the headlight bar are 7mm or 8mm or maybe 9/32, just bring em all.
Old Sep 29, 2007 | 03:45 PM
Engine: L98 5.7
Thanks for the info guys, I appreciate it! I'm going Monday to try and get this piece so I'll let you know how I make out!
Old Oct 1, 2007 | 12:23 PM
Engine: L98 5.7
Hey guys............
I did this the easy way..........I went to a swap meet and bought a whole nose cone for $20.00. I pulled the bracket out and everything was intact. A few of them I looked at were already broken........looks like even a small tap causes these things to crumble.
Anyone need a nose cone for an 82-84 Z28?
Thanks again!
Tony
BewleyBizzIROC
Feb 3, 2020 09:52 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
