GFX questions
Old Oct 10, 2007 | 06:27 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
GFX questions
I dont really like the ground effects on my car... they look so plain.
So i was wondering if the gfx's form the 91-92 models (the ones with the scoop looking things) will fit on my 87 without any modifications... are they easy to find, do the cost a lot more, would it look bad on my car... any info would be good.
Old Oct 11, 2007 | 10:36 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: GFX questions
Im pretty sure that they will fit with no mods... well they will fit but im not sure if there is any other brackets used to mount them. But they will fit. They will look right on your car. Now i dont know how easy they are to find but hey they are around. I also assume they arn't gonna be really cheap. I bought a complete set of gfx and it cost me $260 and they were from a 85-90 car. but you can search on here and mabye get lucky. I have the sides under the door and on the doors from a 91-92 camaro on mine. I dont like them. They are just to rounded fro the square body style. Just IMO I am trying to put the stock ones back on. but yes i think it will look fine on your car. Good luck man. -Matt
Old Oct 11, 2007 | 12:35 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
Re: GFX questions
I know the 91-92 front spoiler uses tabs to mount on the fenders whereas the 85-90 uses bolt-plates to mount.
19Camaro, do you have any side pics of your car with the 85-90 front with the 91-92 side pieces? I'm having a heck of a time finding the 91 front for my 91 rs but can get the 85-90 from certifit for less than $100 new.
Old Oct 11, 2007 | 12:45 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: GFX questions
this question comes up almost every week
Old Oct 11, 2007 | 12:47 PM
19CAMARO85's Avatar
Re: GFX questions
Here ya go. Sorry but the door GFX in the back is kinda loose but i think you get the idea... hope this helps. -Matt
Old Oct 14, 2007 | 03:16 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: GFX questions
i like how the front end looks clean and the rear end looks clean and sporty at the same time. i would say keep it the way it is but then again, to a 3rd-gen fan it looks like a hack job.
Old Oct 14, 2007 | 07:25 PM
Car: 1987 IROC-Z
Transmission: TH350
Re: GFX questions
Does it matter if the gfx came off of a RS or Z28? I noticed there is an indent around the badge and I was wondering if it is a different shape based on the different model.
Old Oct 14, 2007 | 09:02 PM
19CAMARO85's Avatar
Re: GFX questions
no as long as it came off of a 91-92 camaro rs or z28 doesn't matter. you are good to go. -Matt
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
LittleFranks
Aug 20, 2015 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
