ttop large pins
Old Nov 3, 2007 | 08:46 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
ttop large pins
When people say ttops with large pins are those only for 91-92 cars? thanks
Old Nov 3, 2007 | 09:58 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Re: ttop large pins
I'd like to know this too. I've been a bit confused as to the years the large pin units were used. Also, whether it's possible to convert the small pin units to large pin, and what (if any) are the assets of the large pin t-tops?
-Paul
Old Nov 3, 2007 | 10:09 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Re: ttop large pins
I cannot answer the question about what years had large pins.
But yes, it is possible to convert from one pin size to another. Not that hard, either.
Old Nov 4, 2007 | 01:02 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: ttop large pins
Conversion is not required. The two are interchangeable. Once you see the pin in action close up you'll see the plastic pin stop once it's fully seated into the receiver and the inner metal rod continues forward to latch the t-top in place. The inner rod is the same diameter as the older style so as I wrote before, no "conversion" is necessary.
Lon
Old Nov 4, 2007 | 01:23 AM
quadgoat's Avatar
Car: 1992 Firebird
Re: ttop large pins
Cool, thanks Lon! That's kind of what it looked like to me when I took a (rather quick) look at the "large pin" t's on my '92 but I wasn't quite sure. So, what's the point of the plastic outer "pin"? Is it supposed to help stop squeaks/rattles, or what? Is the "large pin" a Lexan-only thing? My Driver's side t-top squeaks like crazy, but if I put slight upward or downward pressure on it, it completely shuts up. Do you suppose the plastic pin is squeaking against the plastic part of the latch on the car?
-Paul
Old Nov 4, 2007 | 08:03 AM
Bull's Avatar
Engine: LT1; None
Re: ttop large pins
-Paul
My car originally gad the Lexan t's. They squeaked like crazy, and as you said, upward pressure would stop it. I tried smearing silicone grease on the pin components, and on the entire perimeter of the t-top where it fits into the roof. Still squeaked.
I finally converted to glass tops, and although they still squeak, it is far less.
I think subframe connectors help to eliminate these damn squeaks...that's my next step.
Old Nov 4, 2007 | 08:18 AM
quadgoat's Avatar
Car: 1992 Firebird
Re: ttop large pins
Yeah, I hoped my SFCs would help. I have UMI's welded in. I guess almost all of the Lexan tops squeak like crazy Funny part is the first few weeks after I put the car together it didn't squeak at all. I drove it to Virginia and back and I really didn't notice it squeaking at all. Now it practically squeaks sitting there at idle! LOL. I've been debating switching to glass t's myself. My Lexan ones are not in very pretty shape, but man I sure do like how light they are, and they don't leak a drop! Although they probably will after I replace my weatherstripping LOL.
-Paul
Old Nov 4, 2007 | 08:33 AM
Bull's Avatar
Engine: LT1; None
Re: ttop large pins
-Paul
I figured that since I'm not a race car driver who needs to shed every possible pound, the extra weight of glass tops were fine by me.
One of the most frustrating experiences I had, though, was replacing my weatherstripping with brand new pieces, and then still having leaks. I spent literally HOURS with solvents and a toothbrush getting all the old nasty adhesive out of the weatherstripping channels, carefull installed the new stuff, and boingo, still have leaks.
I'd rather have a hardtop car sometimes.
Old Nov 5, 2007 | 10:12 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Re: ttop large pins
i hear people ask if ttops are glass or not, i thought all of them were tempered glass. I have tops from an 87 and an 88 are they glass? thanks
Old Nov 5, 2007 | 10:52 PM
quadgoat's Avatar
Car: 1992 Firebird
Re: ttop large pins
Many/most are glass, but the standard equipment for the '91-'92 cars (and maybe '90?? not sure on that one) was Lexan. It's nice and light, but it didn't stand up to the UV (mine are all "crazed" with tiny cracks in the top surface) and it also tends (in my car anyway) to be noisier, since it's more flexible and lifts slightly at higher speeds.
-Paul
Old Nov 6, 2007 | 07:25 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Re: ttop large pins
thanks for the info,
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
