Fender Plug?
Old Nov 7, 2007 | 05:54 PM
Stu's '85 IROC's Avatar
Fender Plug?
Hey, Does anyone know were I can get a metal fender plug to go in the hole after I take off my power antenna? I found a rubber one, but I once saw a metal one on e-bay that fit right in the fender to make it smooth, but now I can't find one anymore. Any ideas?
Old Nov 7, 2007 | 09:05 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Fender Plug?
what do you mean, a patch?
Old Nov 7, 2007 | 09:11 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Fender Plug?
you don't like the radio anymore? just measure the hole and go to a hardware store they have metal and rubber. The metal will need to be bent though and the permanent fix is to get a piece welded in and it painted.
Old Nov 7, 2007 | 09:46 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Fender Plug?
I took mine out a while back, and I plan on welding up the hole when I start my body work.
I put the antenna under the dash pad. The reception is still decent, but IMO the radio sucks these days anyway. No matter what genre you like each station has a playlist of about 12-15 songs that they just play over and over again.
Old Nov 8, 2007 | 12:55 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: Fender Plug?
take a quarter weld it under neath the hole and then fill and sand the top
Old Nov 8, 2007 | 05:30 PM
Re: Fender Plug?
I saw a metal plug on ebay that went right into the antenna hole and made the fender look like it never had an antenna- but I can't find one now.
And I hate the radio (just listen to CDS) that's why I don't care about the antenna.
As for the rest of the ideas thanks a lot.
Old Nov 8, 2007 | 05:33 PM
ryan91rs's Avatar
Transmission: 4L60
Re: Fender Plug?
ya i might get one of those hidden wire one eventually to clean the lines up.
Old Nov 8, 2007 | 07:49 PM
FYRCHKN's Avatar
Engine: LT-1
Re: Fender Plug?
I took my passenger fender off a couple months ago to knock out a dent that was courtesy of the previous owner. While I was at it I put the antenna inside the fender when I put it back on. With the antenna in the fender the reception was basically non-existant unless I was within sight of a radio tower.
I looked everywhere local and couldn't find one of the hidden wire type antennas. Since I was too lazy to pull the fender again I just got an aftermarket stock style replacement antenna for $8 at AutoZone, pulled the dash pad, laid the antenna on the metal in the dash, ran the wire to the radio, and put the dash pad back on. It works pretty good, and no out of place antenna sticking out of the fender.
morrow
Jan 13, 2024 12:29 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
