HELP!!! HATCH WONT LATCH 88 IROC
Old Nov 9, 2007 | 05:29 PM
GEOFF1983Z28's Avatar
CAN ANYONE TELL ME HOW TO GET MY HATCH TO LATCH...THE MOTOR HAS GONE OUT AND I NEED TO GET IT TO AT LEAST STAY CLOSED UNTIL i GET A NEW PULL DOWN MOTOR. I DONT WANT TO DAMAGE ANYTHING BY CONTINUED SLAMMING TRYING TO GET IT TO STAY SHUT.
PM ME PLEASE
GEOFF
Old Nov 12, 2007 | 11:32 AM
ParkerTPIz's Avatar
Re: HELP!!! HATCH WONT LATCH 88 IROC
All u have to do.....if the gears are still intact (which they should be if its not broke; if it hasnt been slammed or damage, (other than the pulldown not working,) ) anyway, if the gears are still intact you can take the back of the motor apart, and crank down the gear manually. ive done it before; it works perfectly.
Old Nov 12, 2007 | 12:11 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Before you go taking it apart try re-setting it. Sometines the pull-down unit will stop before the reversing switch has been tripped to end the cycle. If so it won't go down or up until it has been re-set. Here's how: Reach into the hole where it pulls down and press the striker-sensing switch. It is a small black switch that looks like a paddle that is forward of the latch as you look into the hole. You may need a flashlight to see it. The switch SHOULD energize the pull-down to finish the down-cycle, you'll hear a CLICK which is the reversing switch tripping. Release the switch and the pull-down unit should power all the way up and CLICK again ending the up-cycle. Done, succesfully re-set. Remember that you must hear the CLICk at the end of each cycle up or down. If this doesn't work then follow the Tech Article I wrote that is posted on TGO.
Lon Salgren
Top-Down Solutions
Old Nov 13, 2007 | 01:38 AM
ParkerTPIz's Avatar
Lon Salgren
Top-Down Solutions
My idea was just a quick fix so you dont reak like exhaust, (if youre gonna buy a new one anyway!) but, thats true Lon! give it a shot GEOFF1983Z28 vbmenu_register("postmenu_3526867", true); !
or if not of that works, don you sell a rebuild kit Lon? lol
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
