new here 1988 iroc
new here 1988 iroc
new member been a 3rd gen f-body fan forever. ive have a ton of them and my current car is an 88 iroc-z, 5.7 tpi, 3 inch y, borla cat back, 58mm tb, chip, and some other goodies.
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: new here 1988 iroc
Hey bambam,welcome to TGO.Your car looks to be in pretty good shape other than the clearcoat peel.Have you had it a long time?It appears to be original other than the 85-87 wheels.By the way,what is the other car in the pic?I've been trying to figure it out for the last few minutes,and can't figure it out.
got it in 2001 for the most part just stored over the last few years. plan on some aftermarket wheels, repaint, and engine build and supercharger over the next few years, trans has been built up. gotta love late 80's clear. car has just about every option exc. leather. i also have an 82z and had 86z and an 88 berlinetta.the other car is one of three reason i have not been able to get to the camaro, its a 1965 barracuda, others are a 1971 dodge demon, 1970 340 4 speed duster, and a 1987 chevy 4x4.
yeah it over flowing hard part is keepin all the irons out of the fire at the same time thats why i havent started on the maro. restoring the demon now. i can still drive the iroc.
Yeah bro,I know all too well about to many irons in the fire,I've already taken a three day tour on that boat!!So,the iroc run good?
yeah, she runs awsome the heads need re-done (smokes for a second on start up, comp. is good no leaks and still tpi with a bbk t-body and fesh 700r with b/m internals had some trouble with the rear end, had small center in the 9 bolt and lost the ring and pin so i found a 3 series carrier with 327's and good posi. and with the availible gears may look in to a 10 boltdown the road or just get the 370's
if she only smokes a little on startup,and the compression is good on all cylinders,why not just replace the valve seals without tearing the motor apart.Its a very easy process IMO.
well small blocks are cheap to rebuild and adding a supercharger to it i would feel a little bit better knowing that it was up to the task, its got 100k on it now. plus while the engine is out i can do a first class job on the engine compartment.
here is a pick of my 4x4.
Last edited by bambam16150; Nov 20, 2007 at 09:19 PM. Reason: Automerged Doublepost
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
nice iroc man and KILLER 4x4 that thing is nasty lol let see the other projectss... just a sneek peek. lol -Matt
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
LOL i had a dodge demon......it was a bucket....oringinal slant 6, i ended up getting a 440 running gear from a camper and putting in it.....sold it for alot more than it was worth....lol, WELCOME TO TGO
mustangman65_79
Aug 11, 2015 03:17 PM
