Repairing Rot? I Need Advice!
Old Dec 2, 2007 | 11:07 AM
CRPEPA's Avatar
Car: 1985 Chevrolet Camaro
Engine: V-6
Transmission: Automatic
I bought a Standard 85' Camaro earlier this year, in hopes of fixing up as a project vehicle. I'm in the dark as to how I'm going to fix the rot under the right rear side. I open my trunk to lift up my carpet, as I am looking to replace it, and I moved a few panels around and there I saw rot right through the underside of my car. It needs to be fixed pronto! I searched the rest of the car and it seems to be the only problem area. How do I fix it?? I need to know my first step.
Old Dec 2, 2007 | 01:22 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: Repairing Rot? I Need Advice!
first off you cant fix rot. you can remove it, by cutting out the rotted metal and welding in a patch of sheet metal. you can also stop it from spreading, by sanding out the rust (if it is just surface) and using a good quality primer and paint to seal it. if there is a good sized hole, you are in for a learning experience. if it is just surface rust you should be able to fix quickly, and if it is real rusty but seems fixable the first step is to remove the rust with a grinder, then you can see what needs to be done.
Old Dec 2, 2007 | 02:53 PM
CRPEPA's Avatar
Engine: V-6
Could I have that done somewhere? I want to make sure it's fixed properly.
Old Dec 2, 2007 | 03:10 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
if its jsut surface rust with no holes just go out an get some sand paper and sand it off. if theres a hole either get a welder and sheet metal or jsut go to a body shop an tell them too do it.
Old Dec 2, 2007 | 03:11 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
or a technical high school could do it if they have an autobody shop.
Old Dec 2, 2007 | 03:13 PM
CRPEPA's Avatar
Engine: V-6
My best bet is to have it done for me until I learn how to do it myself properly. Thanks for the help.
Old Dec 2, 2007 | 07:54 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Axle/Gears: 2.73--
Or a high school with a metal shop... They dont need to be in an auto tech class t know you need to cut and weld.
Old Dec 2, 2007 | 08:18 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
didnt think of that, but if he wanted it grinded, filled and painted he'd need an auto shop.
Old Dec 2, 2007 | 08:28 PM
Firebird_dave7's Avatar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
not necessarily, im in auto but alot of my buddys in ag have changed out there exhaust and done custom body work done there so they can if they are skilled but best bet is a auto tech class or auto body class.
jaridjohn
Oct 5, 2015 07:01 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
