Side skirts the same???
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Are the side skirts of say an '88 RS (sports coupe) and an '88 Trans am the same??? I have the side skirts and doors with the door panels still on them from my '88 RS and would like to replace my firebird doors and convert into a T/A body, but i don't wanna put the side skirt set on after painting if it's going to be different looking. I figure the less parts i have to look for at the moment in this transformation the better/cheaper and then i'd just have to get the bumpers and fender skirt extentions. Thanks for any help!
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: Side skirts the same???
way different
Car: 1987 Trans Am
Engine: 355
Transmission: t56
you'll need to weld up the holes from the camaro gfx and drill new for the Trans Am gfx.
figures...thanks for the replys guys
and you'll have to tack weld the metal supports under your rocker panels to support the ground effects.
Thanks for the heads up, i guess i'll have to figure it all out when i end up finding a cheap set and make my own brackets. Thanks again!
pita to make the brackets ... just go with a cordless drill and remove them from a car at the bone yard ... much easier doing it that way.
it would help if i could find a T/A in a boneyard within 50-75 miles of me, i hate upstate NY!!! grr
curious...have you done the convertion before??? or do you just know about this from having a t/a or GTA?
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Car: 1987 Trans Am
Engine: 355
Transmission: t56
cool, thats good news for me because I plan on putting some 91-92 Camaro gfx onto my Trans Am in the near future, and I hate welding on my car.
Engine: that I like
If that's the case, you may not need to do anything at all. The door we put on the '86 T/A was from an '89 RS. A while back I put a '92 RS door on my old '86 IROC and I remember having to elongate the two end holes on that too. That would make me think the T/A uses the same bolt hole locations as the '91-'92 Camaro gfx.
Ask a guy parting one out can't imagine they would ask more then 15 bucks for these braces. If they do ask someone else LOL
Not sure if camaro's used the same braces but from 84-90 the braces on the trans am should all be the same.
PM sent.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
