Rubber Under Coating???
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Ive had my camaro completley repainted and the body has no rust but under the car is pretty rusty. I was wondering if would be a good idea to spray with rubber under coating? Someone told me that it will make the bottom rust faster, by holding in the moisture. Just wondering what you guys think?
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Rubber Under Coating???
that someone was correct.
get a wirewheel and go to town. afterwards, coat with some por15 and be done with it.
i'm in the same boat, just haven't gotten around to it.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Even better than a wire brush lol ... get a little right angle die grinder. Then get a back-up pad kit for it and find some 3M discs. Not the sandpaper discs, you need the scotch-brite type discs.
Just like this picture:
Car: 1991 Camaro RS
Transmission: 700 R4
It's to late for rubber under coating now. The rust is already there. Get yourself an anglegrinder and a cupped knotted wirewheel and about 20 hours of free time and remove as much rust and paint as you can. Then hit it with POR-15.
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I am not sure what that would do to it, but I don't know why you would go with that instead of POR-15 (other than price I suppose). I put POR-15 down on the inside of my floor pan and I must say that it is some really good stuff. Its like thick paint that dries quickly and is very hard once it does. It is supposed to be rust proof, so you can't really go wrong with it if your trying to prevent rust.
I am going to start taking the rust off the bottom of my car with a wire brush and paint it with POR-15 (as soon as I get the engine, transmission, and exhaust out
) as others have suggested, just not sure if I should spray or brush it on. Thats what I would recommend doing.
) as others have suggested, just not sure if I should spray or brush it on. Thats what I would recommend doing. Thread Starter
Car: 1992 Camaro RS
Engine: 3.1 V6
I just want to get it done tomorrow and i dont want to wait to have it shipped to me. plus a gallon is over $ 100. i dont think it can get it done with a quart
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I was in the same position with not wanting to have it shipped, but I decided to wait because its worth it. I am glad I waited on it. If you think about it, waiting a day or two to make something last years to come is worth it.
Just my 2 cents, its really up to what you want to do
Car: 1992 Camaro RS
Engine: 3.1 V6
Very true, im just very impatient lol. I suppose i will just get off as much rust that i can and wait a day or two after christmas to finish it.
Car: 1991 Camaro RS
redformula88
Oct 14, 2015 06:08 PM
