Mixing bumpers from different years, need help
Old Dec 30, 2007 | 09:09 PM
Silver83's Avatar
Hey guys, I have a 1983 Camaro. I don't know the trim, because it has a Berlinetta front bumper, Z28 badge on the dash, and no other badges.
I want this front bumper/lip combination.
This is what I currently have-
My camaro before paint:
Side view after paint:
So can I take that first pictures bumper and install that on my 83? Because I keep searching for OEM bumper covers for a 1983 camaro, and that combination never seems to come up? They are the same, width/length, correct? If the mounting holes are different, I can fix that.
Can some body shed some light on this for me?
Old Dec 30, 2007 | 09:20 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: Mixing bumpers from different years, need help
The ones on the red car were 91-92 only.
Old Dec 30, 2007 | 09:22 PM
Silver83's Avatar
So if I buy that front bumper and lip, will it fit on my 1983?
Old Dec 30, 2007 | 09:29 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I believe you have to cut little notches in the fenders for the lower spoiler to fasten to. Other than that I don't know. I have only worked on one Camaro and it happened to be a 91.
Old Dec 30, 2007 | 09:30 PM
Silver83's Avatar
How does it attach? Screws? Or is it like those plastic tabs you find in the interior?
Old Dec 30, 2007 | 09:34 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
It has little tabs that stick through the fenders. I don't remember what holds them on. It was five years ago and I have only worked on one Camaro since then and it was nowhere near the front. It was a fuel pump.
Old Dec 30, 2007 | 09:37 PM
Silver83's Avatar
Ok, well thanks for all your help.
I think I might do the bumper swap. Thanks.
Old Dec 30, 2007 | 09:47 PM
Stephen's Avatar
Car: 87 GTA
They'll swap, you may just need to drill new ground fx holes, and/or fill the old mounting holes.
Not sure, but I think the mount bars & plastic impact strips are the same or at least, interchangeable. But they'll definately bolt up, without changing the mounts..
Old Dec 30, 2007 | 09:57 PM
Silver83's Avatar
Ah, ok. Thanks man.
Old Dec 30, 2007 | 10:25 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
you can actually use a 1985-1990 or a 1991-1992 front bumper. The only difference is in the ground effects...which will work on either bumper.
Old Dec 30, 2007 | 10:27 PM
Silver83's Avatar
Oh, I never noticed that.
Do the ground effects mount the same?
Old Dec 30, 2007 | 11:20 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Give a PM to 83Z28BlackBetty (Jake), he just finished that same conversion last summer. All he lacks are the trim pieces for the doors.
Old Dec 31, 2007 | 11:32 AM
Silver83's Avatar
Will-do! Thanks man.
Old Dec 31, 2007 | 01:16 PM
83Z28BlackBetty's Avatar
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
hey, Al is right. i did this 2 summers ago actually. There are 2 main components, the bumper cover and the lower spoiler. the bumper cover is the same from 1985 to 1992. The lower spoiler you want is referred to as the aero style and only came in 1991 and 1992.
You will need to find a bumper from a 1985-92 car and the spoiler. The bumper cover bolts directly on using 3 bolts on each side that come through the fender, you need to reach your arm up inside the wheel well and find them (total PITA) then the lower spoiler bolts right on to the bumper cover. the part about the notches is where the scoops attach to the fender (right infront of the wheel) i didn't cut notches in mine, i used small machine screws to screw it in from whithin the wheel well. this held it in place much tighter although it is not the stock way to do it. Check out my car domain page, there are tons of pics there. (click on the pic in my sig)
If you need any more help please ask, just shoot me a pm, i try to check frequently.
~JAKE
Old Dec 31, 2007 | 06:29 PM
Silver83's Avatar
~JAKE
Thanks man, I'll check that out!
Old Jan 1, 2008 | 11:43 AM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
If the impact bar is the same as an '83 Z28, the later impact bar and absorber will be needed too.
BTW, I find it's easier for me to remove the upper bumper cover to fender bolts by using a swivel and extension from inside the engine compartment. Everyone has their own preferred way though.
colton_carlson
Mar 8, 2019 12:21 PM
krisner89
Oct 10, 2015 06:03 AM
mikey8494
Aug 22, 2015 07:57 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
MENINBLK
Aug 5, 2015 11:58 PM
