Dent removal-84 Z28
Old Jan 13, 2008 | 01:53 AM
Sdk09x's Avatar
Car: 84 Camaro Z28
Engine: 305 V8 HO
Dent removal-84 Z28
So I have a 84 Camaro Z28 HO. It has some rust and all, but some sanding could take care of that. But I have a small-medium size dent behind the drivers side door. I was wondering what would be the best way to take care of it? Any idea's?
Old Jan 13, 2008 | 01:15 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Dent removal-84 Z28
Have any pics? "Small- medium" could mean very different things depending on the person.
Old Jan 13, 2008 | 01:43 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
we need pics, but if its more of a medium size Id use a stud welder and slide hammer to pop it out, or you could try to reach it with a hammer from the inside of the car.
Old Jan 13, 2008 | 08:31 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
You'd be surprised what u can do with a stud welder and a little time
Old Jan 15, 2008 | 01:27 AM
Sdk09x's Avatar
Car: 84 Camaro Z28
Engine: 305 V8 HO
Thanks, I will try to get pics up in today. How much would any of you guess it would cost to get the dent pulled at an auto shop?
Old Jan 15, 2008 | 09:16 PM
Sdk09x's Avatar
Car: 84 Camaro Z28
Engine: 305 V8 HO
Here are some close up pics of the dent. They arnt the best pics, but yeah.
Attached Thumbnails Dent removal-84 Z28-01-15-08_2003.jpg   Dent removal-84 Z28-01-15-08_2004.jpg   Dent removal-84 Z28-01-15-08_2005.jpg
Old Feb 2, 2008 | 07:28 PM
Shred's Avatar
Car: 1986 Iroc-Z
Engine: 350cid crate
Transmission: t5- 5speed
Axle/Gears: stock
ya man u are in the same boat i am. This is what happens when you try to move your vehicle the morning after new years, and dumbass is parked sideways beside you. the door will have to be replaced. for the body though, can u get a hammer in behind from inside the car?? also, if I buy a door with a dent protection strip down the middle, can it be removed easily??? I mean, is it fastened on or is it just put on with adhesive??
Old Feb 2, 2008 | 07:33 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
the door ding strip is held on with adhesive, some fishing line or even string will take it off. as for that dent you'd be better off with a stud welder or even maybe a frame machine to pull it out.
Old Feb 2, 2008 | 07:42 PM
Shred's Avatar
Car: 1986 Iroc-Z
Axle/Gears: stock
interesting thanks, do you have any idea what it would cost to get the body dent fixed?
Old Feb 2, 2008 | 08:40 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
it depends if you could get it out with a stud welder or not, but Ill let someone with more expirence chime in because I have no clue how much it would cost.
Old Feb 8, 2008 | 07:26 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Based on what I can see, that dent is doable by PDR. I can't tell if the edge by the door jamb and the wheel well will come back perfectly or not since this is just a picture. It will need repainting so PDR will get it 90% or better and those edges might require a little bondo. A stud welder/puller will cause more body work than is necessary.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 22, 2015 08:28 PM
Night rider327
Sep 16, 2015 02:20 AM
hydrolic144
Sep 8, 2015 06:59 PM
