87 Berlineta Quarter panels
Is there a company that makes reproduction quarter panles, because im working on restoring a 87 camaro berlinetta, and don't much feel like patching/bondoing the current ones, also i have a question not related to the body at all, but could i put a 383 in my car, or does a 383 use different motor mounts than a 305, also would a 383 fit in the engine compartment without having to chop up car in there, because if it fits ill put in new motor mounts
-Tj
-Tj
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: 87 Berlineta Quarter panels
no idea on the 1/4 panels but all small blocks are the same size and use the same mounts
any quarter panel off any thirdgen camaro works. they just look different because of the ground effects that come from the front bumper (and the gfx can be removed there) ....so hit the junk yard
So i take it i couldn't steal a quarter panel off of a 87 firebird, cause i have one of those I'm parting out, actually i don't need the entire panel, just the lip on it, and yes i know its a bitch welding them in
Car: 1985 Camaro-1986 Trans-Am Cross
Engine: 5.0L, Fresh From A Rebuild
Transmission: 700R4 Shift Kit
Axle/Gears: 3.03 Std.
my 85 berlinetta had a rough patch one the rear quarter panel,i eventually had it professionally done, it just refused to turn out right when i welded pieces in. as for the motor, the intake and the heads may sit a little higher. all blocks are not created equal, there are one-piece rear-main and two-piece, depends on the car and the only issue i forsee would be the height, i only have a 305 and i had to cut the hood bracing to fit my 14" air filter in, just to give an idea how little room there is.
Car: 1987 Trans Am
Engine: 355
Transmission: t56
if you just need the wheel lip it should work, but the whole quarter from firebird to camaro differs, an example is the taillights, camaros wrap around while firebird tails dont.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
masterhacker198 Where are you located ??
I've got a Passenger side rear quarter panel from a Z28 for sale.....$125 But I will not ship it. It might be an option for you depending on where you are located !?
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
To the person who said a 383 may be taller, the rear seal design has nothing to do with the hight of the engine. It all comes down to the intake/carb/air cleaner combo
i know, i used that as an example that not all small blocks are the same, as someone had mentioned earlier
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
