Undercoating...pics
Old Jan 22, 2008 | 07:19 PM
texan_rebel's Avatar
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
Undercoating...pics
ive been wanting to undercoat my car since i have it all stripped down but the axle so i tried it out today just seeing what yall think.
1st thread before 2nd after
Attached Thumbnails Undercoating...pics-0122081356.jpg   Undercoating...pics-0122081357.jpg   Undercoating...pics-0122081358.jpg
Old Jan 22, 2008 | 07:20 PM
Car: 1989 RS camaro
Engine: 350Ci
Re: Undercoating...pics
after pics
Attached Thumbnails Undercoating...pics-0122081422.jpg   Undercoating...pics-0122081447a.jpg   Undercoating...pics-0122081422a.jpg
Old Jan 22, 2008 | 07:28 PM
Car: 1989 RS camaro
Engine: 350Ci
sorry i had to take the pics with my phone cause i couldnt get the pics from my digital camera to upload on the fourm
Old Jan 22, 2008 | 07:47 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
makes a big asthetic difference and helps slow down rust. definately looks better than before did you scrape off any loose stuff before putting new on?
Old Jan 22, 2008 | 07:58 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
What did you use to do it? I think bedliner spray would be the ultimate undercoating.
Old Jan 22, 2008 | 08:40 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks alot better. what'd ya use?
Old Jan 22, 2008 | 08:41 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Just a guess... but they make this stuff called....
RUBBERIZED UNDERCOATING!!! lol
Old Jan 22, 2008 | 08:59 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Eastwoods sells a gun to spray undercoating and bedliner. It gives it that really textured look. Pretty cheap too. For the undercoating, you can just use Duplicolor truck bed liner in the gallon can.
Old Jan 22, 2008 | 09:40 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
i've used it before on a frame and it's the only part that did not rust! lol.
Old Jan 22, 2008 | 10:11 PM
Car: 1989 RS camaro
Engine: 350Ci
i pressure washed the bottom then wiped it down with grease and wax remover, I used 2 different brands, duplicolor and a 3M product, 3M was about 10$ a can and the dupilcolor was 5$ in my opionion the 3M was better, but it is the rubberized undercoat, i was also thinking about spraying the back inside since the inside is striped out, but not intil i put the roll cage in.
I appricate the feedback but it does look better in person hopefully it might cut back some exterior noise....maybe?
Old Jan 23, 2008 | 11:23 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
How difficult is it to use that stuff? I was planning on using a roll on kind for the bottom of my IROC. The rust isn't bad but I don't want it getting worse, and since I live in WI all the water and salt and such aren't really good for it. Unfortunately I'll have to wait until spring since I have it all tucked away.
Old Jan 23, 2008 | 12:09 PM
Car: 1989 RS camaro
Engine: 350Ci
it really wasnt difficult at all just make sure you clean were u gonna spray and spray it on, i didnt have rust on my camaro i live in texas but i figure since its all tore apart i would go ahead and do it, i think it looks good, but it is messy i got that sh*t all over me hard to get off the skin. I also have the inside all apart i think im gonna spary from the back seat to the back.
Old Jan 24, 2008 | 01:41 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
yea do yourself a favor. get a wire wheel and attack every bit of rust. i spent 3 days getting all the rust off and undercoating every single place i could. even jacked up 2 feet in the air with no suspension on it it sucks but its so worth it though.
