91-92 camaro gfx bracket?
Old Jan 29, 2008 | 12:29 AM
Kandied91z's Avatar
anyone know if you can still purchase the side gfx brackets for 91-92 camaros?
or by any chance does someone here have one... looking mainly for the front drivers side (not sure if sides matter) that help the gfx attach to the front fender. basically behind the z28 emblem?
lost my brackets when i took my car apart 2 years for paint and it's the last piece i need to have it all back together..
Old Feb 1, 2008 | 09:25 PM
Kandied91z's Avatar
Re: 91-92 camaro gfx bracket?
anybody... ? it's the last piece and i can finally have my car together.
Old Feb 11, 2008 | 12:28 PM
Kandied91z's Avatar
come on guys no one here has a bracket laying around they do not need? please don't make me half to buy a whole new drivers side lower gfx..
Old Feb 11, 2008 | 12:33 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
I work at a GM dealership i can check and see if they still sell them new if you want??? let me know
Old Feb 12, 2008 | 12:13 AM
Kandied91z's Avatar
sure please do as i've tapped all my gm resources and can only find the bracket if you buy a new gfx and there is only one remaining left in the system. if you look into it you'll find out where..
Old Feb 12, 2008 | 12:20 AM
Kandied91z's Avatar
ok let me ask all of you this since over 100 people have looked!
does anyone know for a fact what other years in the thirdgen production you can mix and match this bracket to mount the side gfx.
for example: did this vary on the irocs or the trans am models?
Old Feb 12, 2008 | 02:07 AM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Just go to a JY and find a 91 or 92 and take the bracket you need off. . . . You dont need a new one do you?
Old Feb 12, 2008 | 07:19 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Your still fairly new here. Kandied is known for having one of the nicest thirdgens on the board. You dont get that status by just picking up any junkyard part. Its details like this that wrap it all up.
Kandied. I dont see why the bracket would be any different between rs/z28. I believe it is different for camaro to bird, but have not verified that.
Old Feb 12, 2008 | 08:17 AM
AC's Avatar
AC
Car: Used to drive a camaro
Kandied, if I remember right (on my 91) there is a front & back bracket, along with the rocker "rail" that are used to fasten the rocker panel gfx. Is this the bracket your asking about? I dont' have an answer as to where to buy it but if you can tell me which one you need I may be able to machine / fab one up that is up to snuff quality wise for you to use.
Old Feb 13, 2008 | 10:53 AM
bad86z28's Avatar
Hey, if you're still looking, I know I have one in my garage.
Old Feb 13, 2008 | 02:26 PM
Kandied91z's Avatar
i would if it were that simple... they are hard to find here in michigan in a junk yard. i can't currently justify paying $1,000 for a used one just to rip off the bracket at this point in time.
I have 3 others sitting in my garage but i don't want to pull apart other cars to do this as i'll eventually need another. i didn't think it would be this difficult to find but it seems to be.
as for the bracket being new or used honestly it wouldn't matter as long as it's in good shape. i can sand blast it and coat it so it's basically new again. with this particular piece being the last piece that would be ok.
i know for a fact it is not different between 91-92 camaros however i do not know if it is different from other year seperation camaros such as iroc models. also i do not know if the bracket is different from the pontiac versions.
i can't imagine it would be too different as that would incure more costs to gm... but the fact i do know is that i don't know.
yes this is what i'm looking for. it is a two prong bracket with little wings or tabs on either end of the bracket to support the ground effect. it mounts the lower drivers side ground effect to the front fender. it has to be a drivers side one as the two are different.
how much shipped to 48047 michigan? as long as it isn't all bent up or rusted out meaning i could clean it up, paint it to keep it from rusting and use it i'd like it.
let me know as i can't find one anywhere... i know they are out there but i'm just not having any luck.
Last edited by Kandied91z; Feb 13, 2008 at 02:29 PM. Reason: Automerged Doublepost
Old Feb 13, 2008 | 02:54 PM
AC's Avatar
AC
Kandied, I'll see what I can come up with quick like. Say by the end of this weekend?
Old Feb 13, 2008 | 03:21 PM
Kandied91z's Avatar
sure, let me know.
Old Feb 13, 2008 | 04:30 PM
Dale's Avatar
Engine: 350 S-TPI
The 86-90?? (fiberglass w/o vents) didnt even have brackets on them.. or atleast the ones I took off a j/y car. They had studs that went strait into the body. So you will need 91-92.
Agree on chevy to pontiac.
Old Feb 13, 2008 | 06:20 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
I'm 99% sure I have one also. Working right now, I'll send you a pic in the morning. Seeing as how you've been looking for awhile, about $200.00 should cover it + shipping! j/k I'll go easy on ya.
Old Feb 13, 2008 | 06:25 PM
bad86z28's Avatar
Kandied - Just so we're on the same page, I've attached pics of the bracket. If you want it, PM me your address and I'll put it in the mail tomorrow. How fast do you want it?
Attached Thumbnails 91-92 camaro gfx bracket?-img_1561.jpg   91-92 camaro gfx bracket?-img_1562.jpg
Old Feb 13, 2008 | 06:31 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I looked for some new ones a few months ago. I came to the conclusion that there are no new ones . I ended up taking them off of a parts camaro that I had. It takes a little work to drill out the 14 or so spot welds . That was on an 89 though. My guess is that you will need to find someone to get the bracket from if you can't get to a junk yard car.
Old Feb 13, 2008 | 10:01 PM
karl's-92'-z28's Avatar
Car: Too many cars
Just curious, is it hard to make a bracket that would work correctly, or are you going foe the O E M look?
Old Feb 17, 2008 | 02:45 PM
Kandied91z's Avatar
yes i just found this out... they all have brackets but the irocs and pontiacs are different from the 91-92 camaro. the camaro aero kit brackets have little wings and are not universal on each side of the car. they are actually labeled left and right. i need a left or drivers side... well actually i'll take both a left and a right if someone had them.
please let me know. thanks!
hmm... more about the time. i don't have the time unfortunately to even think about messing around with that. it just seems easier to track one down that someone has laying around... seemed easier i should say.
Last edited by Kandied91z; Feb 17, 2008 at 02:46 PM. Reason: Automerged Doublepost
Old Feb 17, 2008 | 02:50 PM
Kandied91z's Avatar
that is exactly what i'm looking for. i need a left and a right but only truly need a left at the moment to get the car together!
i sent you a pm. if anyone has a set like this or more importantly the left/drivers side one alone please let me know, thank you!
they are labeled left and right, i can use both but am in need of the left most importantly!
Old Feb 18, 2008 | 09:39 PM
Car: Too many cars
Good luck with your search, I'll look down here & let yu know if I find any.
Old Feb 23, 2008 | 04:08 PM
Kandied91z's Avatar
finally my search is over, thanks everyone!
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
toronto formula
Nov 10, 2015 06:17 AM
jahblah
Aug 12, 2015 05:54 PM
