weather strip problems
Old Feb 7, 2008 | 03:30 PM
racerx520's Avatar
two summers ago, i replaced the t-top seals on my car (but only on the car...not on the t-top itself) so for christmas i asked for the t-top only seals, as the back of the passenger side seal sprung a leak and during hard rain storms i'd find a small pond in the back of my car.
today i replaced the seals on the t-top itself, and i gave it a little 'false rain' (a.k.a. put the hose on the roof) and by golly, there is still a leak...i think i can see the problem and that is where the seals are supposed to butt together, there is just a little tiny gap there...
is there any way to patch this up other than buying a new passenger side t-top seal?
thanks,
-Brian
Old Feb 7, 2008 | 06:23 PM
noc_81's Avatar
Re: weather strip problems
Did you seal everything up with the good 3M weatherstrip adhesive/sealer?
Always a good idea to check the tech articles... I see a T-Top weatherstrip install guide and a leak fix guide.
https://www.thirdgen.org/ttopleakfix
https://www.thirdgen.org/ttops
Old Feb 7, 2008 | 08:42 PM
racerx520's Avatar
well i know where the problem is, and the problem is that the gap needs to be filled, and i don think that RTV will work....any other suggestions?
Old Feb 8, 2008 | 07:15 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
buy some 3M weatherstrip adhesive. It's not as thick as caulk so will run into the area that needs filling.
Old Feb 8, 2008 | 10:50 AM
racerx520's Avatar
i have that, but that would work if i planned on gluing my t-tops down....the gap is in the back most right side of the passenger t-top seal...where the seal from the t-top itself meets the seal from the car itself....there is a gap between those two seals that needs to be filled somehow, preferably if i could actually pull the seals on the car out a little, that would fix it, but theyre glued in place with the 3M weather strip adhesive
Old Feb 8, 2008 | 12:27 PM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
Originally Posted by racerx520
i have that, but that would work if i planned on gluing my t-tops down....the gap is in the back most right side of the passenger t-top seal...where the seal from the t-top itself meets the seal from the car itself....there is a gap between those two seals that needs to be filled somehow, preferably if i could actually pull the seals on the car out a little, that would fix it, but they're glued in place with the 3M weather strip adhesive
i had the same problem before i put my car away for winter. i filled the hell out of that spot with chalking, now it doesn't leak there, but you cant open them up again without breaking the seal.
Old Feb 8, 2008 | 12:39 PM
racerx520's Avatar
lol yeah thats the problem....i did that one winter before i changed the seals on the car itself...and man, even after i took the tops off, there was still residue on the seals and the tops....but that was also an attempt to try to see if i could build up RTV to try to make the seal a bit higher, i figured then it wouldnt leak....too bad in my stupidity i didnt realize that RTV never fully dries and that it stays kinda tacky lol....whoops, but me and my dad are going to try to figure a way to see if we can move the t-top seal on the car at all...i doubt it, but we'll see.......
Old Feb 8, 2008 | 12:46 PM
you can try using a needle witha calking and filling those i guess numbs?full, maybe they will expand a bit, enough to seal.
Old Feb 9, 2008 | 07:13 AM
scottmoyer's Avatar
can you post a pic of the gap? What brand weatherstripping did you buy?
Old Feb 9, 2008 | 10:32 AM
racerx520's Avatar
i believe its OEM...i bought it from hawks...i will try to get a picture of it, it is a small gap though, i am bringing it to my dad's shop on monday so i'll try to get some pictures of it then
Old Sep 12, 2008 | 11:16 AM
viper123's Avatar
Most commonly, the t-top leak would be a door window that is out of adjustment, causing the glass to be too high vertically-which lifts up on the t-top window, causing a gap between t-top glass and the seal.
Old Jul 29, 2009 | 05:17 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
LittleFranks
Sep 17, 2015 12:22 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
g.l.mos
Aug 22, 2015 12:02 AM
