Do I need a whole new antenna?
Old Feb 13, 2008 | 09:51 PM
90BlackGTA's Avatar
Car: 1990 Trans Am GTA
Axle/Gears: 3.42's
Hey everyone, when I bought my GTA last summer the power antenna doesn't work. Not sure exactly why but I know that I don't ever hear the motor running so does that mean I need to buy a whole new unit? Because there a very cheap not used oem antenna package for sale off ebay...Thanks, Josh
Old Feb 13, 2008 | 10:02 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Re: Do I need a whole new antenna?
Does the car still have the stock radio, or an aftermarket. If the radio has been changed out I would check the blue trigger wire first. Somethings just don't always stay together when they've been rigged. Also some cars have a separate fuse for the pwr ant, but I don't know about yours.
Old Feb 13, 2008 | 10:03 PM
90BlackGTA's Avatar
Axle/Gears: 3.42's
Hmm thanks, better check that stuff first...I have an aftermarket cd player in it
Old Feb 13, 2008 | 10:19 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Is your mast up all the way???? Its not uncommon for the mast cable to break when the antenna is up. Most guys just unplug the antenna and call it a day. I have rebuilt a few where the motor still works but the plastic cable that raises or lowers the mast is broken.
You can still buy that piece at Wheatons for about 15-20 bucks......
Old Feb 14, 2008 | 06:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you don't hear the relay click, it may be unhooked (to prevent contstant operation).
JamesC
Old Feb 14, 2008 | 09:48 AM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
My bonneville had the same problem. the mast broke but the motor kept running. since this is my daily driver, i left the antenna up, but i unplugged the motor, so now it is just a normal antenna.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
