Do 85-90 TA GFX get 3M tape in between body and plastic?
Old Mar 4, 2008 | 03:03 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have a 1983 TA that I converted to 85-90 TA body, and painted a few weeks ago (for the 2nd time). When I did the first respray I bolted the ground effects right up against the body using all the stock hardware from a donor car. I did not use any trim tape. But this time I bought some of the expensive 3M super strength body trim tape just in case.
Did the factory use body tape in between the plastic and body or not? If not I'll leave it out. Obviously the gfx are held on plenty strong by bolts. I just figure that the tape will keep water from running down inside the GFX.
Old Mar 4, 2008 | 03:30 PM
Firebat's Avatar
Re: Do 85-90 TA GFX get 3M tape in between body and plastic?
No, factory didn't use any adhesive between. It might not be a bad idea though. I'm actually heavily considering it when I get my car repainted.
Old Mar 4, 2008 | 03:37 PM
Car: 2000 BMW M5
The only thing I'm worried about is if the tape will be of negligible thickness. I don't want to wind up with a gap. On a lot of belt line trim, a slight gap caused by foam tape is not noticeable. However, w/ the TA ground effects, any gap would look horrible. Maybe I will test fit one of the rear pieces w/ the tape and bolt it down and see if it gaps at all. If so, at least I'll only have to scrape tape from one piece.
Old Mar 4, 2008 | 05:40 PM
jeffcj's Avatar
I don't have anything to contribute here, but I just had to say... NICE paint!
Old Mar 4, 2008 | 05:53 PM
Car: 2000 BMW M5
Oh on the 2nd gen? You can buy it if you want to. I am swapping the built EFI'd 327 out of it and into the 3rd gen TA I am finishing color sanding from new paint. I have the 2nd gen as a rolling chassis up on craigslist (northern VA area)
Old Mar 4, 2008 | 06:01 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Instead of using tape, I would use a bead of clear silicone sealant. This should help cut down on the amount of moisture that can get between the rocker and ground effect, but it can be removed without harming the paint.
Old Mar 4, 2008 | 06:02 PM
Car: 2000 BMW M5
Silicone is a huge No. I'd use nothing at all before I did that.
Old Mar 4, 2008 | 07:06 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
yeah,I wouldn't use that either,and I don't think you'll need the tape either,the gfx should be just fine as they are from factory as long as all the brackets are in good shape.
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Nightcruzer
Aftermarket Product Review
29
Jan 19, 2010 02:13 PM
david auster
May 25, 2003 08:55 PM
Jims83TA
Dec 31, 2001 12:36 AM
