Outer skin on door is coming off.
Old Mar 4, 2008 | 06:47 PM
ino's Avatar
ino
Car: 87 firebird
Is it common that the outer skin of the door on 3rd gens to come apart? Mine has started to come off a bit in the corner. Anyone else having this problem, if so is there another fix besides replacing door.
Old Mar 4, 2008 | 06:55 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Outer skin on door is coming off.
as far as I know,its not a common thing.Is there rust involved?
Old Mar 4, 2008 | 06:57 PM
camaro 1984's Avatar
mine did the same thing i just switched the door
Old Mar 4, 2008 | 07:06 PM
ino's Avatar
ino
Car: 87 firebird
No I dont see any rust.
Old Mar 4, 2008 | 07:18 PM
I've never seen this,got any pics of you're problem?
Old Mar 4, 2008 | 07:42 PM
theboilermaker's Avatar
Car: 87 camaro sc
Engine: 357 w/ cc qjet
Transmission: 700 r4
clean it really well. Then epoxy it together. Make sure to seal it so that it does not rust. A picture would be a big help though
Old Mar 5, 2008 | 11:37 AM
ino's Avatar
ino
Car: 87 firebird
Yeah, I wll try to get a picture.
Old Mar 5, 2008 | 05:05 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Iether get a welder and do some sheet metal work. Or you can order a door skin from year one and weld on a small peice on your "inner" door part. Also call your local junk yards becuase doors are cheap i bet you could find one for like 50 bones
Old Mar 6, 2008 | 04:29 PM
ino's Avatar
ino
Car: 87 firebird
This is the picture of the corner where it started to come apart.
ok thanks
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
