Stock Hood?
Old Mar 8, 2008 | 09:38 AM
EH82Z28's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 10 Bolt, 2.73 open diff
Stock Hood?
I don't know why, but for some reason I want to keep the stock hood on my 88 camaro. I had a stock hood on my 82 Z28 and I had some clearance issues with the motor. The air cleaner wanted to push up the center of the hood. Is there anything I can do to stay with the stock hood if I want to run a carbuerated motor with an air cleaner?
Old Mar 8, 2008 | 10:01 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Re: Stock Hood?
drop base air cleaner
Old Mar 8, 2008 | 02:24 PM
EH82Z28's Avatar
Engine: 305 TBI
Re: Stock Hood?
Is a drop base air cleaner something that you can find easily? How much more clearance could I expect to gain?
Old Mar 8, 2008 | 02:52 PM
rockin rs's Avatar
Re: Stock Hood?
Cut a ****in fourteen inch hole in your hood, (where the air cleaner is) and just weld a scoop on there and repaint it. If that doesn't sound like so much fun, look around your area for a speed shop. They should be able to track down that drop base cleaner for you.
Old Mar 8, 2008 | 09:56 PM
EH82Z28's Avatar
Engine: 305 TBI
Re: Stock Hood?
I said I wanted to keep the stock hood. Not hack it all up. I like the flat clean look of the factory hood. I found this drop base on summit's site http://store.summitracing.com/partde...5&autoview=sku so hopefully it will be enough to get the clearance that I need.
Old Mar 8, 2008 | 09:59 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: Stock Hood?
Should be, depends one which intake you run but you can make some carbed setups fit under a flat hood.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
bryan623
Aug 10, 2015 11:33 AM
