Front Nose Hood gap alignment problem...hlp..
Old Mar 17, 2008 | 11:18 PM
TTA656's Avatar
Car: ****TTA****
Engine: Bad A$$ Buick motor
Transmission: 2004r
Ok what I am thinking is that the painter forgot to put in a bracket in the location of the pink marks in one of the pics,would installing the bracket there fix the problem or does more new to be aligned.. thanks for any help.. Dennis
Attached Thumbnails Front Nose Hood gap alignment problem...hlp..-012tta.jpg   Front Nose Hood gap alignment problem...hlp..-011tta.jpg   Front Nose Hood gap alignment problem...hlp..-010tta.jpg
Old Mar 17, 2008 | 11:54 PM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
Re: Front Nose Hood gap alignment problem...hlp..
You're right, there is suppose to be a bracket under there and yeah, it would probably fix your problem.
Old Mar 18, 2008 | 07:46 AM
TTA656's Avatar
Car: ****TTA****
Transmission: 2004r
Thanks ,thats what I was thinking ,but never had the car apart to this extent to notice the bracket,thanks I will get one installed and see what happens ...
Old Mar 18, 2008 | 10:17 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
I have the exact same hood gap, and also do not have a bracket in that indicated location. Can someone post a pic of this bracket and what does it do? I don't ever remember there being a secondary attachment for the hood nose to latch on to, and even if there was I'm not sure how it would fix the gap other than bending the nose downward....
Old Mar 18, 2008 | 10:45 AM
Merlin86TA's Avatar
Car: 1986 Firebird T/A
If I am not mistaken it will actually push the nose up some, and that should make it line up better. I had the same problem on my 86 TA, and after putting that bracket back in, the hood and bumper lined up right.
Old Mar 18, 2008 | 12:36 PM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Interesting.
I'm going to research this, I'd like to fix the gap on mine.
Old Mar 18, 2008 | 02:41 PM
Pocket's Avatar
Car: 91 Trans Am
There is a triangle bracket that you are missing
The hole labeled as II is not used
The bracket wont lift the nose that much, it is more for stability
Old Mar 18, 2008 | 02:44 PM
Now why the hell would anyone just have their support bracket laying around to take a picture of???
I dont know, but I do. As you can see the bottom of mine is bent becuase some jackass before me appartently tried to jack up the car by the core support. btw, thats where the bottom of this goes, is the core support, that's why it pushes up on the panel, which therefore pushes the edge of the nose up which helps it line up with the hood, and yes it will push the edge of the nose up, because mine lined up perfectly until this was removed(there is a reason behind it being temporarily removed but its a long story).
btw, I like you're username Gunner823. Gunner is actually my boys name...my boy being a 100+lb German Shephard, its also the beginning of my email addy.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
