Removing emblem adhesive?
Old Apr 28, 2008 | 02:58 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I am getting ready to put a new set of emblems on my car. Now I just took the Z28 emblem off my bumper, and now I am stuck w/ this thick black adhesive that is hard coming off. Anybody know what can be used to get this stuff off? Any help would be great...Thanks
Old Apr 28, 2008 | 03:01 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: Removing emblem adhesive?
usually Goo Gone with some rubbing gets off most any adhesive. Might have to coat it a few times if the adhesive is thick. Then you wash it off after the area is cleaned so it doesn't eat into the paint.
Old Apr 28, 2008 | 03:10 PM
85maroz28's Avatar
I tryed Goo Gone and 3m Adhesive Remover with no luck...
Old Apr 29, 2008 | 09:24 AM
85maroz28's Avatar
ttt
Old Apr 29, 2008 | 09:58 AM
Stephen's Avatar
Car: 87 GTA
I used a different brand, maybe, but the same type, to remove the "bumper strip" along the side, doors, fenders, rear quarters, on my black Tahoe. ZERO damage to the black paint. Chuck it in your drill, ans spin away!
It ***** up the adhesive to fall off, then any polish/wax type stuff will remove the adhesive glazing remaining, making it like it was never there.
http://www.detailgear.com/index.asp?...ROD&ProdID=200
Old Apr 29, 2008 | 06:45 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
WD-40
Works every time.
Spray it on, rub it in, let it sit for awhile.
Couple apps and should come off.
Later
Old May 1, 2008 | 05:28 PM
85maroz28's Avatar
Thanks guys... anyone else?
Old May 5, 2008 | 06:41 PM
EH82Z28's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 10 Bolt, 2.73 open diff
eraser wheel and a drill
Old May 8, 2008 | 03:37 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
409 all purpose cleaner! it removed all of my old decals.
if that doesnt work then lacquer thinner will. be careful if you have old emamel paint
Old May 8, 2008 | 03:52 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Use good old WD-40. It takes off the glue without a problem. You could use it to get tar and other crap off your paint.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
SlowAZ28
Sep 2, 2015 05:19 AM
