i bought the new t-top weatherstripping
Old Apr 28, 2008 | 06:41 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
i just got my new weather stripping in the other day so me and my dad installed it the other night, we followed all the instructions and cleaned everywhere. and did all the silicone work. now the car leaks on the drivers side and the middle of the t-tops. the passenger side is fixed.... for now anyone have any ideas on what i should do. it really pisses me off that i spent 255 on weatherstripping for it not to even work
Old Apr 28, 2008 | 08:10 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: i bought the new t-top weatherstripping
Man, that sucks!
I'd be ticked off, too.
Maybe a good body shop would have some suggestions for you?
Old Apr 28, 2008 | 08:53 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
I wouldn't panic just yet. Have you adjusted your t-tops down? Also, did you put sealant under the t-bar?
Old Apr 28, 2008 | 11:10 PM
Rva's Avatar
Rva
i cant get the t-bar to come off, i fixed both my t-tops from leaking but now the tbar is leaking its a s s off
Old Apr 29, 2008 | 12:42 AM
oil pan 4's Avatar
Car: 89 Firebird
My t-tops leaked because the seal on the top glass went to hell.
I used 3M Yellow weather striping glue to glue it in place it so it doesn't move any more and put Black RTV over that mostly to cover the yello and protect it form sun light.
Old Apr 29, 2008 | 11:39 AM
Rva's Avatar
Rva
RTV?
Old Apr 29, 2008 | 03:57 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Originally Posted by Rva
RTV?
RTV can be bought at stores like auto zone, if im not mistaken its pretty much a rubber gasket that you could use for things like your rear end or manifolds, the previous owner of my car used it to fix up my t-tops, it doesnt look pretty but it works pretty good.
Old May 1, 2008 | 11:29 AM
Rva's Avatar
Rva
o iC
Old May 2, 2008 | 12:15 AM
oil pan 4's Avatar
Car: 89 Firebird
Black RTV over the 3M weather striping glue.
It doesn't stand out at all. I for got it was on there untill I saw this post again.
Old May 9, 2008 | 06:55 PM
Rva's Avatar
Rva
how much is it cause i cant stand this leaking anymore its leaking worst then it was before i bought the new weatherstripping
Old May 10, 2008 | 07:06 PM
oil pan 4's Avatar
Car: 89 Firebird
Its likely not the weather striping, its the seal between the T-top glass and the locking mechanism.
There is no way to replace that seal. Just use Glue an RTV like I did. It should at least last several years.
86IROC112
Sep 7, 2015 01:37 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
