iroc z hienz 57 what yrs are they from?
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well the body is an 89 my front shin guard has slots, my hatch has the third brake light atop ,instead of in the spoiler. does anyone know what year the hatch is so i can get replacement bulbs?
Car: 87 z/28
Engine: 305 tpi
Transmission: auto 700r4
Axle/Gears: not sure 2.73 I think
Re: iroc z hienz 57 what yrs are they from?
im new to the third gen camaros but it should be86 or older .i dont know what year they started putting third brake lights in.I have an 87 z-28 ipretty sure that was the first year they were put in the spoiler
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i see you own an 86 . if i post a couple pics can you tell me where a few wires go in the hatch area?
Car: 1991 Trans Am
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
1986 is the only year with the third light on top of the hatch, according to this website tech info. you can also check with iroczone.com and they will tell you the same thing. or you can type in third gen info and check out many other tech sites and they all say it too. i'm no expert, but i have an 86 and i've done my share of home work, and all of my research has said 86 is the only year with high mounted third brake light. 87's have the light in the spoiler
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
here they are.
the green wire is attached to cargo light.the third brake light i was curios bcuz 2 wires go in ,but only 1 comes out. and the other has a plug end on it and i can't see anywhere it goes.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Your front shin guard will be an 91-92 style. If the sides have "vents" they will be 91/92 as well. Rear bumper will be slightly different for 91/92 as well.
IIRC, that black single wire may go to a light in the "trunk" area. But more I think, I had a black wire like that in my old RS that went to nothing.
The two wires on the hatch. Could go to a spoiler light which you should have. Or to rear defrost.
Car: 1986 Iroc-Z
Axle/Gears: 342
could those wires be for a power hatch? some camaros came with an electric hatch motor that would pull the hatch down tight once you close it.
just a suggestion.
just a suggestion.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
hatch pull down works perfectly. i just wonder why it doesn't have a hatch release. i have the wires that plug into the cargo light however i dont see a switch for it. but i know it works. the wires on the hatch itself is for the brake light what i question is why there is two wires going into that plug on one side then only one coming out the other side of the plug.
Engine: 350 S-TPI
oh, I didnt notice that. I thought it was hidden due to black behind it. Hum..
there is no switch for the cargo light in rear.. on either of the 3 f-bodys I have worked on. It comes on when doors are opened, or doam light is turned on.
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I bought a '86 firebird when it was new back in the day and shortly the year after the '87's Camaro speaking here had them in the spoiler until '91 I beleive Joined: Nov 2005
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
86 on top of the hatch
87-89 in the spoiler
90-92 inside the hatch
Just to clarify, the 86s had the third light on the glass for all models. The 87s had them in the spoiler on cars that had spoilers. If you had a Camaro without a spoiler, it was on the back glass just like an 86. All 87 up Z28s and IROC-Zs had them in the spoiler until 91 when they went to the inside of the window.
And I'm sure they are all very low optioned cars, not even having a spoiler, base models with the smallest engine available, manual windows, locks, transmission, no AC, ect. They were the "Ad" cars. Dealers order them so they can advertise a brand new Camaro for a low, low price. Then you when get to the dealer, you end up buying a more expensive, optioned car.
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I agree, now that I can remember that is how I got my bird back in '86 mine was a base model, with just a AM radio and in the dash was just a speedo and gas guage and shift light, but the selling point for me was that she had a base v/8 with 5 speed (carburated w/ electric choke) and A/C (florida) so it had a little better pick up than a v6 for the time, and it was fun to drive being that it was brand new in all so the suspention was tight and hearing those secondaries open up on the 4 barell open up on the rochester was cool too, all that for just a shade over $9,000 in '86 for a car with no miles
mustangman65_79
Aug 11, 2015 03:17 PM
