Side Mirror Swap (HELP!!)
Old May 5, 2008 | 06:54 PM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
OK here's the deal, Car has manual mirrors, bought power mirrors (housing and all) housing is white, car is red.
I want to try and swap the power mirror insides into the manual mirrors on the car.
Is it just the 3 screws that hold the mirror insides in the housing? I was looking at the power mirror and it looks like I can get at 2 of the screws but I don't think I can get at the 3rd.
Any help is greatly appreciated!!
-Chris
Old May 5, 2008 | 07:35 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Side Mirror Swap (HELP!!)
You have to pop out the glass piece on the power mirror to get to the other screw.
Pretty simple procedure,just be patient and get behind the glass piece and pull it off.There are three pins on the back side of the glass that work the power mirror,they are inserted into the power window motor.I guess you could say they're kinda like worm gears.Sorry I don't have any pics of this,but try like I said,give a firm tug on the glass piece,and take a peek behind it,that should give you an idea on what you're looking at.
Old May 5, 2008 | 07:50 PM
Car: 91 Camaro RS
Axle/Gears: 323
OK so I'm actually looking to pull the glass part of the mirror off all together? I just want to be certain so I don't break anything!
Thanks again!!
Old May 5, 2008 | 08:17 PM
Yes,the glass part as well as the black backing that the glass is glued to.
I consider them 1 piece,but wanted to clarify that.
Old May 5, 2008 | 08:33 PM
Car: 91 Camaro RS
Axle/Gears: 323
I figured you meant that but thank you!
I got them apart with no problem just a thin long screw driver and they popped apart with no problem!!
Thanks again!!
-Chris
Old May 5, 2008 | 09:34 PM
No problem,glad I could help.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
