Noob Questions...
Old May 12, 2008 | 07:59 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
Noob Questions...
Need help from the Experts... I have a couple questions...
1) Which is better when sanding down bondo on quarter panels? Hand-Block Sanders, or Sander Bits on a Dril?
2) How hard is it to re-create the crease that goes along the center of the quarter panel?
Old May 12, 2008 | 08:05 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Noob Questions...
block sand all your bondo by hand, it'll come out the straightest if you go at around a 30* angle with the block.
that "crease" is a body line that gives the metal strength, whats wrong with yours?
Old May 12, 2008 | 08:09 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
This is my problem... The big dent... couldnt pull it out...
Old May 12, 2008 | 08:15 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
how'd you try to pull it out?
Old May 12, 2008 | 08:21 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
From inside the trunk, Tried banging it out thru there....
Old May 12, 2008 | 08:28 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
I hope you aren't planning on filling that whole area with bondo! Drill a couple holes and use a dent puller, get it as close to factory as you can, then use the bondo to finish it up, trust me, you'll be happier.
Old May 12, 2008 | 08:32 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
no use drilling holes, use a stud welder with a slide hammer, will pop it right out then use a little bondo to finish it up and get the line nice again.
Old May 12, 2008 | 08:37 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
yeah,what he said.
This kid knows his stuff!
Good luck man,and let us know how everything goes.
Old May 12, 2008 | 08:39 PM
lasher_350's Avatar
Engine: 5.7 L98
Replace the entire quarter panel lol
Old May 12, 2008 | 08:42 PM
PolarrrBearrr's Avatar
You have a lot more going on there then just a dent. Your whole panel is out of alignment. Your spoiler part on the end might be a little messed up too. And they are both right - you can't fill that with Bondo.
Old May 12, 2008 | 08:45 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
You think it might just be the angle of how i took the picture that makes it look out of alignment? I think i sha'll try to do the slidding hammer, I'll go pick one up at the store tommorrow... Any suggestions on which brand? or where to get a good one?
LoL... Trust me i thought about it, But would rather save the piece thats on there now...
Old May 12, 2008 | 08:50 PM
lasher_350's Avatar
Engine: 5.7 L98
lol I said replace the quarter panel because that's what I'm looking at...to fix what some previous dirt road rumbler did to my car...
Not looking forward to fixing it. bluh.
Old May 12, 2008 | 08:52 PM
panel looks fine to me around the spoiler area.
It may just look out of alignment in the pic as you stated.
Old May 12, 2008 | 08:56 PM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
Wow... That blows, And i thought i had it bad... I just bought the Iroc i'm working on... Is that an RS?
Old May 12, 2008 | 10:27 PM
lasher_350's Avatar
Engine: 5.7 L98
It's a plain old Z28
Old May 13, 2008 | 10:07 AM
SinZ's Avatar
Car: 89 Iroc Z
Engine: 5.0
Nice... Think urs does need a panel replacement...
Well if i use the Slidding hammer where should i drill the holes on the dent? and will this pop the crease back where it should be?
Old May 13, 2008 | 10:36 AM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
first of all, the best wat to do it would be to use a stud gun. it welds rods onto the panel and you use a slide hammer to pull the dent. i wouldn't recommend drilling holes. also.. i think you should be more concerned about the rust issues. you could get that dent looking perfect but if you don not take care of that rust properly it will spring right back up in 6 months or a year and you will be hatin' life.
Old May 13, 2008 | 03:21 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
stud gun welds studs to the panel, no drilling holes involved, then the slide hammer just grabs the stud and pulls the dent out...
Iroc88z28
Apr 28, 2003 11:05 AM
HamsterOnaMission
Apr 4, 2003 08:21 PM
Kaps
May 1, 2002 10:02 PM
Biochem
Carburetors
Oct 22, 2000 05:50 PM
