How to put ground effects on a non GFX car
Old May 14, 2008 | 08:39 AM
85camarojunkie's Avatar
Car: Camaro coupe
I have a 85 sport coupe. Its ready for paint but i want to throw side skirts on. The rear bumper is easy, just drill wholes in rear quarter. The side under the doors have mounting brackets welded to the body from factory. Can i buy a bracket online to correct this or is there an easier way
Old May 15, 2008 | 12:32 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
Re: How to put ground effects on a non GFX car
you need special mounting brackets for the gfx.
you will have to tap and drill holes. all along the body of the car for the side skirts i beleive its like 6 or 7 holes that need to be drilled.
same thing for the gfx on the doors..
its tought to align the door gfx with the side skirt. but take measurements and make marks.
if you are off just a hair. drill on the same hole but down . obviously.
it took me with a lift..
about 2-3 hrs a side.
its such a pain in the ***. but its worth while in the end.
ill post some pics of my before and after.
i just avoided your question.
yes you need 2 "brackets"
its one looonnnnggg bracket thats the length of the one side of the car. that has slits in certain locations to accept screws for the gfx/
i tried getting them from my local chevy dealer. but obsolete.
they looked up some vintage place for the long brackets.
they were around 50-60 bucks each. you need 2.
good luck
Last edited by Simply-305; May 15, 2008 at 12:34 PM. Reason: Automerged Doublepost
Old May 15, 2008 | 01:30 PM
Car: Camaro coupe
any idea on part numbers or what. Thanks for response. I can do anything on these cars but thought skirts were going to be easy.
Old May 15, 2008 | 02:12 PM
Simply-305's Avatar
do not have any part numbers. but i beleive there is a business called "vintage auto parts" or something like that.
if you have patience and time...
it can be done. but dont be surprised if you take measurements 6 times and it comes out slightly crooked. it will happen.
go on your favorite search engine and do a search on that business. if anything ill call my parts friend and ask him for a website or a phone number.
BRoss99
Aug 10, 2025 05:08 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
gwade12
Aug 8, 2015 08:17 AM
