Hatch pull down keeps running....
Old May 14, 2008 | 05:08 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
I did a search and am having a hard time finding the correct answer.
I have an 86 Firebird, and the hatch pull down motor keeps running after I drop the hatch down. It tightens, but when it looks like it should stop it keeps running. I have the relay unplugged right now.
is this a relay problem or something else?
Old May 14, 2008 | 05:15 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Hatch pull down keeps running....
Sound like the teeth on the plastic gear for the pull down is stripped. Download the repair instuctions from Top-down solutions for the parts you will need.
Old May 17, 2008 | 02:21 AM
birdflu's Avatar
I would check the switch in the pull down assembly. the lever may have broken off.
Old May 17, 2008 | 02:31 AM
89TXIroc's Avatar
Car: 89 IROC 5.7
Engine: 357
I once had this problem when my plastic gear was stripped.after replacing the gear, i installed the motor too far down and it would never stop pulling. so try raising the whole assembly a small amount until it stops pulling
Old May 17, 2008 | 07:49 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
yes make some quick adjsutemnts but not sure why its giving you trouble now.
mess with the rubber adjustment screws, mount the motor assembly alittle higher.
you should hear a nice "click" meaning the motor is no longer running and the trunk is fully closed.
83 Crossfire TA
Jan 3, 2016 01:26 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
