Blinker lenses????????/
Old May 22, 2008 | 01:37 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
My blinker lenses on the front are fogged up and dirty. this is just from age, and i want to know if i can clean them with anything or do i just have to replace them??? any info is good. thanks
Old May 22, 2008 | 01:41 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Re: Blinker lenses????????/
They can be sanded down with a very fine paper. Do a search on the board there are several posts on the correct way to do it. I will do a search too and post if I could find it.
Old May 22, 2008 | 01:47 PM
goomaan's Avatar
Car: 1987 IROC-Z
Found it
https://www.thirdgen.org/forums/auto...gnal-lens.html
Old May 22, 2008 | 01:49 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Hey thanks for taking the time to do that. I will try that, maybe even tonight.
What grit sandpaper should i use???????
Old May 24, 2008 | 01:10 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ok, so i took off my blinkers (what a pita that one bolt was). i got some really really fine sandpaper. i mean this stuff could have past as newspaper. and then wetsanded my blinker lenses. they are clear now and look good. but i got moisture on the inside, how do i get that out. do i have to take off my blinkers again and let them dry, or will it just dry as it is?
Old May 25, 2008 | 08:10 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
drill a hole in the bottom where u wont see it to let the house "breath"
Old May 25, 2008 | 08:28 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
i am going to have to try sanding and polishing mine. because they are already off and they look like junk. i am also considering getting some of the clear ones off of ebay with the mirror backing. but that will have to be next year.
Old May 27, 2008 | 03:28 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
well, i did nothing with them since then, and they are starting to dry out, very slowly, but they are. o and the sanding looks good, they are almost perfectly clear again.
irockid, when you sand them, use very very fine sand paper, and wet sand them. if you already know that then just disregard it, not trying to insult you, just some advice if you didn't already know.
my next project: the headliner
Old May 30, 2008 | 01:46 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
just an update, my blinker lenses are all dried out. i just let them sit, and it cleared up. they look great.
Old May 31, 2008 | 12:43 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
GM TSB Regarding Condensation in the Turn/Park Lamps
Old May 31, 2008 | 07:22 PM
irockid86's Avatar
Car: 88 iroc camaro
Axle/Gears: stock
two things. first, i dont know if i would want to cut any kind of grove or hole in my bumper cover. second, i just used some "scratch out" on the lenses and it did a great job at removing the cloudyness but there is still some pits. over all they look 100% better and it only took about half an hour. i also washed and rinsed the inside out so that may have helped some.
Old Jun 3, 2008 | 02:35 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
you don't have to. just leave them sit, they will dry out. it just takes a few days. mine are good-as-new now. they look great.
oh, and krisb410.....i have you beat in milage. 199,xxx and still counting
Fronzizzle
Feb 9, 2017 09:31 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
