What would cause a door not to line up?
Old Jun 7, 2008 | 01:21 AM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
For some reason the tops of the doors in my firebird don't sit flush. What would cause this?
Attached Thumbnails What would cause a door not to line up?-imag0107.jpg   What would cause a door not to line up?-imag0108.jpg
Old Jun 7, 2008 | 03:06 AM
grthrawn's Avatar
Re: What would cause a door not to line up?
well lets see door sag meaning you need to replace bushings if not try aligning it its not that hard just 6bolts
Old Jun 7, 2008 | 09:14 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I am having the same problem with mine, except the bottom is out and the top is in to far. I do not think it has anything to do with door sag. Door sag is up and down, this is in and out.
Messing with the bolts that hold it on didn't do anything for me. There is no adjustment in the bolts because they have to be all the way in to be tight and hold the door on properly.
I haven't found the solution as of yet, and my thread didn't turn out any ideas that worked. Maybe this one will have better luck.
Old Jun 7, 2008 | 12:16 PM
SDalt404's Avatar
Car: 1988 GTA
I think I will just take it by a body shop and have them fix it.
Old Jun 7, 2008 | 12:27 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Just hit it with a hammer! Kidding. Sorry, I shouldn't have even replied, but I couldn't resist.
Oh, and if the hammer doesn't work ... get a bigger hammer!
Old Jun 7, 2008 | 12:28 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
That's definatly a hinge alignment problem, I don't have much experience with the Firebirds/Camaro's, but I know most cars have 2 sets of bolts on either side of the hinge, one side adjusts height, and distance, the other adjusts how far in, and how far out from the car the door sits.. But take it to a shop, it's a stressful job.
Old Jun 7, 2008 | 04:44 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I played with the hinges on mine a little bit. The only thing I found that fixed the problem was leaving the top hinge bolts a little loose, but that is unacceptable since it won't hold the door on properly. The hinges on these cars have bolt holes the size of the bolt, no movement can happen. I can see hinges effecting up/down alignment, but how can they effect the door's rear in/out alignment?
Old Jun 7, 2008 | 05:25 PM
SDalt404's Avatar
Car: 1988 GTA
Thats why I am taking it to a body shop...
Old Jun 7, 2008 | 05:35 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Than if you don't mind, could you ask them what they did to fix it once they finish and then let us know? I don't have the luxury of taking mine to a body shop so I am kinda stuck with the problem. I would greatly appreciate it if you could post their solution.
Old Jun 8, 2008 | 03:20 PM
N3M3S1S357's Avatar
Car: 1988 Pontiac Fiero Formula
Engine: 2.8 HO
Transmission: 3spd Auto
The problem is with how heavy those big doors are. The hinges just start to get worn and droop. Inspecting the hinges, grabbing a beer, a mallet, and a lot of patience can help. I've seen a lot of places selling hinge repair kits that seem to do pretty well. Either way it's a pain.
Old Jun 11, 2008 | 04:42 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
EXACT same thing haooebned to my car. forget maaco as they wanted to bend the door to fit and whaty not
tuned out to be worn door pins/bushings and what not. maaco wanted over $1,000 just for bending the door...before paint...cost me $80 at a really reputable shop and it was fixed in a day
Old Jun 12, 2008 | 03:06 AM
redltcamaro's Avatar
Car: 1987 LT Camaro
Engine: Empty at the moment
Transmission: thats out too
Axle/Gears: 4.11
it looks like besides your hinges being misaligned, your knocker is also misaligned.
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
AkDrifted
Aug 17, 2015 07:45 PM
